4-20 mA pressure transducer
·Can anyone tell me if there is a website that shows how to connect a 0-10 bar pressure transducer to a BS2P40. The sensor is a danfoss MBS5150, input 10 - 32 vdc.Output 4-20mA. Im trying to get the reading in Bar on a parallel LCD. All help more than welcomeThanks
Alan
To convert the 4-20mA, you can put a precision resistor 250 ohm 0.1% in series with the input current.
It will convert the 4-20mA into 1 to 5 VDC.
From here you can supply the voltage to a analogue to digital converter(ADC) example ADC0831 to get the digital signal to supply to BS2.
regards.
Kam
Thank you.
Warm regards.
Kam
You can check below webside as well:
About current sensor:
http://www.allegromicro.com/
To download the 'Basic Analog and Digital' Student Guide:
www.parallax.com
regards.
Kam
Thank you.
Warm regards.
Kam
