·hi can any body help, need to output the FMG3 i have on stamp to display result and save to file on pc
can see the output in debug.but need to down load to pc (win 98 or xp) thanks ·allan
You can view the debug screen in Hyperterminal.· Close the debug screen, open Hyperterminal, set Hyper to capture the display to a file, then run your program to display whatever you want.
Hyper must be set for 9600 baud, and direct to whatever Comport you are using.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Sid Weaver
Try the Stamp Tester
Allan, you can use the same technique to save data files, EEPROM readouts or anything your Stamp can display.· If you capture to Excel, you can capture up to 50 channels and 65,000 data points.
Sid Weaver
allan
Sid Weaver
allan
