EMIC to Cermetech dialout and voice status
Ok, I wasn't sure how to describe what I was after in the subject line....guess that means I'm in trouble already! haha
Anyhow, what I'm after is this:
we have some equipment that we monitor (it's a radar...).· We monitor some things and would like to be informed via phone, of any faults that might occur.
Currently we use a pager system and an old PC w/modem.· The PC has some basic circuitry that it monitors and when things go bad, it dials the pager service and gives it a certain numeric code indicative of the current problem.
The pager system is pretty bad.· It's limited in coverage and the PC is running some old DOS software with some customized C program (the maker of which has long ago retired)....so this system has a finite lifespan nonetheless.
I was looking at using the stamp for doing some of the monitoring (or having a PC to the monitoring and give basic status bits to the stamp.
The stamp would then use an EMIC speach module and a Cermetech modem kit.
The Cermetech has some analog inputs (for voice) and I could connect the Aout of the EMIC to that.
It seems somewhat straightforward....but I don't want to fork out too much $$ if it can't be done (as far as the EMIC to CERMETECH).
I notice the modem is backordered....any word on getting more in Parallax?
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
Steve
It sounds like a simple tone dialer, which can be accomplished with the Stamp, along with an audio input to the phone line should be all that is required of the communications portion of your project.
Or maybe I missed something...
Many are cold...
· but few are frozen...
If I didn't use the modem IC...how would I get voice on to the phone line.· And hacking a telephone isn't an option.· I'd like this to be a somewhat compact/self-contained box.·
But I supposed there's many ways to skin the preverbial cat!
Steve
Jon Williams
Dallas Office
However, having dialed a cell-phone, I believe the CERMETEK could leave a text message to be displayed to the user.
And, with the CERMETEK module, you get the commercial DAA and license.
By the way, you can do this with ANY RS-232 connected Modem, you know. The BS2 can stand in for the PC, in that case.
the current system we are using is a pager system....I know it'd be no big deal to have the stamp issue modem commands and such to give us indications on a pager as to what's going on.
But we were looking at a way to get rid of these pagers and go with something that could dial us and "tell us".
The Cermetek has TxA and Rxa which, as I've read, are analog I/O's.· Being that it's a modem module, I could only assume that it doubles for Voice or Data and this is the voice inputs.
I don't have the datasheet available atm but am pretty sure I read as much.
Steve
1) Dial system -- leave in command mode.
2) Wait for system to answer (you could monitor RXA) and get ready
3) Send your audio message via TXA.
4) Hang up
The Parallax modem AppMod uses the CH1786, but does not have the RXA and TXA pins brought out to headers -- you'll have to do a bit of [noparse][[/noparse]warranty voiding] surgery.
Jon Williams
Dallas Office
Hope that helps, and I hope I haven't offended any Stampers,
Tim
Jon Williams
Dallas Office
