74hc595
How·many 74HC595 chip can be chained together?
Newbie, using the NX-1000 24/40 Board with a BS2p40
With regard to this, there is a concept called "fan out" which specifies how many inputs a given output can drive.· If it is not·specified on a particular datasheet, you can calculate it by finding the values for the input high and low currents and the output source and sink capabilities.· Then divide the latter by the former to find the maximum number of inputs that can be driven.· Generally, you wouldn't want to load the outputs to the maximum.· Rather, it is best to leave a little margin for good measure.
Don Kinzer
