DTMF additional frequency (harmonics)
hi,
i'm trying to make a dialing through a basic stamp 2P-40 using DTMF command. however when the circuit is connected, and dialing is made... the DTMF command doesn't seems to be functionally properly...
when my group tried to troubleshoot through a spectrum analyser, an additional harmonic has appeared at 100Hz frequency, no matter what number dialed.
is this 100Hz frequency critical??
regards;
black_tag
regards;
black_tag
Jon Williams
Dallas Office
regards
You might check your powersupply first. Just to be sureit is not coming from there.
Klaus
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
E.g. when number 1 is dialed, the frequency harmonics·will be generated as 697Hz & 1209Hz (http://www.ece.utexas.edu/~mason/codesign/dtmf.html)·and 2 frequency will occurred at the output, however the frequencies occurred on my Spectrum Analyzer are : 100Hz, 797Hz & 1309Hz ...
can any guru of BS2SX·tell me what had happen...
regards
Jon Williams
Dallas Office
i tried to break down the circuit and test the functionality of each component, and realized that the 1:1 transformer happened to be <100 Ohms...(78ohms to be exact tested with my analog Multimeter)·will there be any problem due to the improper value of·transformer???????
the given figure for the hardware connection·is·value at 600 - 600 ohms....
Regards
