Problems downloading program to BS2
I've made my first PCB with a BS2SX.
My problem is that i cant download my program to the stamp, but·I can see the debug output from the program running in the stamp (the program running was downloaded while the stamp was in an education board)
What can be wrong ??
I·think it is the ATN pin. It is connected as shown here:
http://forums.parallax.com/attachment.php?attachmentid=36205
I'm a little confused about the lower 0,1 uF lyt. Is it to be connected to "ground" or VSS ?? What is "Ground" on my PCB ??
//akj
//akj
Your programming connection should look something like the attached image (both caps are 0.1 uF)·-- if it doesn't, you'll need to do a bit of board surgery with an exacto knife and jumper wires.
Jon Williams
Dallas Office
Ion
Also check the power connections, and battery
Jonny
