Javelin Video Switch
Does anyone know if it's possible to make a javelin chip listen for info on serial port, and when it gets it change the input to a tv to a certain device? For example, if I have a cable tv connection, and two computers which I also want to use with the tv for a monitor, could I plug all the inputs into input ports on the javelin's board (with converters and whatever is nescessary), and then make the javelin chip connect the output (tv, also plugged into the javelin board's port) to the right input when told to do so from the serial line? I can program fairly well in java, I just don't know how to go about this with the javelin so any help is appreciated. If you're thinking "just go get a video switch", I would, but I want to be able to change it remotely (don't ask why) and I like making homemade electronics. If this makes no sense, sorry. Thanks.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1103/ln/en
and here
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3953
and I am sure Maxim has more videoswitch ic's, some use I2C.
regards peter
Jon Williams
Dallas Office
so that one can be controlled with the Uart class.
regards peter
