Same port for programing and display
I use a bs2pe24 on one of my projects with a serial lcd display from seetron.
On my aplication i run out of pins and instead to use an expander (new pcb, more code and headecs) i read in the help file ( tip of the day) that the programing port of the stamp can be used like any other serial port with the address at pin 16. Let asume , that i want to use it for my display and get back that most wanted extra pin for an other output. How I can program the stamp on the same port when i do changes during develpment.
I know that i have to remove the display and conect the programing cable, but from the software point of view, the display is updated for every loop of the program , so it will want to transmit to my pc data and it will not listen to the incoming program. To use an extra input to put the stamp in stop mode, will defeat the purpose.
Can anybody help me on that?
Thank you
Ion
Thank you
Ion
Jon Williams
Dallas Office
I will try it, and follow your recommendations.
Do you ever sleep?
Ion
Jon Williams
Dallas Office
