Serial ports
I have a situation where the PC is talking to a peripheral using Visual Basic.
The data the PC receives must be passed to a Stamp.· If I connect the Stamp to a USB port can both ports be used simultaneously?· Does the Stamp receive the VB data from the PC as serin 16.......?
Thanks.
Sid Weaver
Try the Stamp Tester
Thanks.
Sid Weaver
Jon Williams
Dallas Office
I have the feeling that I do not really understand what you mean. Do you have an USB to serial adapter to feed your Stamp or are you using a serial connection from PC to the Stamp? Or do you use your USB cable just to power your Stamp.
Lots of questions as you can see. Can you point out a little more what you are doing??
Klaus
Jon Williams answered by question - the PC is using the serial port to communicate with a peripheral device.· The Stamp is using the USB port to communicate with the PC via a USB to serial adapter.
Sid
OK, now it is clear to me (takes a while sometimes
Does this USB to serial adapter give the power for the Stamp as well?
Klaus
PS Hi, Klaus - hoe bent u?
In Holland we say: "how is it going"
Jon Williams
Dallas Office
No, no power from the USB.
Sid
The only thing I wanted to point out is that Dutch people and American people sometimes say the same things in a different way.
I actually have a datalogger running here on USB power, it draws 40 to 140 mA. It is not a problem for the stability of my datalogger but if I ad other loads (ie 'real' USB devices) to the same port voltage drops from 4.8 to 4.3 Volts. Lucky enough when designing my datalogger I have put in a compensation for supply voltage changes.
I like to power small devices (up to say 150 mA) with USB, mainly because there is a USB hub with free ports on my desk. It's so easy.....
Klaus
The dropoff doesn't seem to affect the Stamp but it does affect the LCD.
Even so, I think the USB-powered Stamp board·is still a very good thing.
Sid Weaver
Jon Williams
Dallas Office
You can solve a lot of USB power problems if you use a powered hub.
The power does not come from the PC but from a separate power brick (2A for 4 USB ports)
So, USB is NOT really 5 Volt, it is more or less between 4.5 and 5.5 Volts which is not as good as a LM7805 by far
Regards, Klaus
Thanks for the tip on the FTDI chips. They may give my project a major impuls as it is devellopping.
There is only one thing I could not figure out yet, I will need suitable prototyping boards for 32 pins on 30 mil spacing and I did not find them here in Europe until now. Does Parallax stock them as well?
Thanks again, this is a good tip !!
Klaus
Sid Weaver
For a DIP you are totally right.
This is for the FTDI chip Jon mentioned earlier in this thread and the pakage is called LQFP-32. It is a square chip of 7x7 mm with 8 pins on each side. This makes the pin spacing 0.8 mm or 30 mil.
So, in case I go on with this and start soldering these miniature pins there will be no beer and no coffee for a couple of days in order to get my hands stable enough
Klaus
I think you can buy adapter sockets for them - not sure.
Sid Weaver
The smalles size I did until now was 50 mil, but that was before I got my glasses and my magnifieing lamp. I have a miniature soldering Iron and 0.5 mm soldering wire for these things.
Unless I find a better way I may have to go this road.
But this FDTI chip is very interesting, you get not only USB power supply but also USB data transfer. I like it !!
Klaus
Here are some prototyping adapters from the LQFP-32 format to DIP format which may be helpful: http://www.epboard.com/eproducts/protoadapter1.htm . Just too bad they're so expensive!
Bruce Bates
Jon Williams
Dallas Office
I just tell you, otherwise some people might miss it, it is only 0.28x0.28".
I'll find a way, this tip from Bruce should work for a prototype but it will give me a 32 pin DIP connector, which is a fairly large shoe for such a small chip.
Klaus
One of the firms that sells FTDI parts, (see their website, no I don't remember it.), sells premade boards. Your choice of either serial I/O, or parallel. But I appllaud Parallax for selling the FTDI parts, they need another dealer. The only ones that FTDI had chosen, until Parallax were a bit odd.
Buck Rogers
www.gregg.levine.name
