CMUcam
Has anyone tried using the CMUcam with the javlin stamp? If so does is take any extra code interfacing with it beyond what is·needed for the BS2?
Yeah I have been using it. I have so-far got the sv (move servo) commands to work via the TTL serial. I am using the following UART declarations, and have connected via the two pins via 220ohm resisters, and a TTL ground. I have not used the 5volt TTL power as it seems to cause power issues.
// CU-CM2 CAM UARTS (PIN7 (IN), and PIN8 (OUT)
static Uart CUCM2RX = new Uart(Uart.dirReceive,CPU.pin7,Uart.dontInvert,Uart.speed38400,Uart.stop2);
static Uart CUCM2TX = new Uart(Uart.dirTransmit,CPU.pin8,Uart.dontInvert,Uart.speed38400,Uart.stop1);
Not got onto anything more complicated yet!
James
