Problem running Javelin IDE in Windows XP (Error IDE 0022 - Error reading from
Hi Everyone!
I have been programming my Javelin Stamp with my old Presario 1230 laptop running Windows 98.· Everything was great until this laptop died a couple of days ago.· Now I am trying to program the Javelin Stamp using my other·laptop running Windows XP Pro.· I already had a USB-to-Serial cable (Iogear) so I thought that the installation and setup would be a breeze and I could continue programming my Javelin Stamp.
Man, what a nightmare.· The Javelin IDE can find the Stamp on either Com1 or Com3 and even performs a successful·Test Connection on Com Port 1 or Com Port 3.· But when it comes to downloading the program to the Stamp, watch out!!!!· The error above appears on Com Port 1 or Com Port 3.
I·would greatly appreciate any help in solving this problem.
Thank you in advance for any advice that you can give me.
Jon Williams
Dallas Office
Thank you so much for taking the time to help me with my problem!
I just placed an order with Parallax.·
Have a great weekend!!!!
Jon Williams
Dallas Office
did you re-assign port number to COM1-COM4? at FTDI Virtual COM Port driver on Control Panel.
I'm not sure that Javelin IDE can use port name more than COM4 or not..
HKEY_CURRENT_USE\Software\ParallaxInc\JavelinStamp\
At the end of the list you'll see ValidPort0 - ValidPort3 -- change any of these to match your USB VCP.
Jon Williams
Dallas Office
I am also experiencing the same type of error, " [noparse][[/noparse]Error IDE-0022] Error reading from the serial port (timeout)." on my new USB BOE connected to my Dell 8300 (3.0 Ghz Pentium 4.0, 1.0 GB Ram) which is running Windows XP Professional Version 202 Service Pack 2.
I am using version 1.0.2154.0 of the FTDI driver, which I downloaded from www.ftdichip.com. (The Parallax USB BOE web page indicates that drivers are not necessary on Windows XP systems. However, my computer would not recognize the hardware so I had to get the drivers from FTDI.)
After installing the drivers, the Javelin appears on COM Port 5. Using the "Identify" Command, the Javelin Stamp IDE (V2.0.3), can see the Javelin on Port 5. Also the "Test Connection" appears to execute successfully. However, any attempt to download code to the Javelin using the "Program" command ends in an " [noparse][[/noparse]Error IDE-0022] Error reading from the serial port (timeout)." error.
Any suggestions to fix this problem? Thanks!
That sometimes helps.
regards peter
I tried decreasing the both the COMPORT receive and transmits buffer size. Neither change fixed the problem. I still get the " [noparse][[/noparse]Error IDE-0022] Error reading from the serial port (timeout)." error.
Mark
[noparse][[/noparse]Error IDE-0022] cause of mapped port number is COM5, it's not direct support on Javelin IDE (valid on COM1-COM4).
it's need to modified by edit registry key HKEY_CURRENT_USE\Software\ParallaxInc\JavelinStamp\
and changed value that Jon had told above..
or force FTDI USB to Serial port number within COM1-COM4 (that's currently not in used) on top most combobox on property near FIFO Rx-Tx buffer
It's should to be okay.
When I am using COM5, I am able to get the Javelin IDE to recognize COM5 by deleting all the ports listed in the "Edit Port List" dialog and typing the "auto" button in that dialog. At that point, the Javelin IDE seems to recognize that a Javelin in on COM5 (the "Identify" and "Test Connection" functions work). However, I get [noparse][[/noparse]Error IDE-0022] when I try to download. If I use REGEDIT at this time, one of the ValidPort will already be 5, so I don't need to edit any ValidPort.
I have also changed COM5 to COM2 and I still get the same problems. The Javelin IDE is able to see the Javelin at COM2 (in the "Indentify" and "Test Connection" function), but errors out [noparse][[/noparse]Error IDE-0022] during a download.
Mark
If it is set to hardware (RTS/CTS) that may be a problem.
regards peter
anyone?
thanks
someone please help... thanks again
I am following the Javelin IDE closely right now-
Jon is correct, certain USB to Serial devices DO NOT WORK. Certain ones do. I do not have an 'official' list as of yet.
Ryan
Ryan Clarke
RClarke@Parallax.com
I recently bought the Professional Development Board (PDB) together with the Javelin Stamp module. My problem is, that I can't program that module with either of my computers (the IDE can detect it on any COM port, even comunication works). I'm always getting the same errors as you guys did: [noparse][[/noparse]Error IDE-0022] Error reading from the serial port (timeout).
I'm using the latest USB <-> Serial drivers from FTDI (2.00.0). I checked all my settings; baud rate, COM port #, etc.. but nothing works out!
Please help me!
Thank you,
Martin
If you have a Serial Port try the standard Serial Port connection. The USB connection and the USB-BOE seem to have an unknown issue with timing once a very small program has been downloaded to the Javelin. You may need access to a PC with an on-board Serial Port to get a larger program downloaded, essentially refreshing the Javelin. I hope this helps. Take care.
I just hope, that FTDI can find a solution concerning this matter (If they know about this, that is)...
Martin.
