Heavy-weight robot with tank treads.
Ok, I think my next project, which will be my first significant robot, will be a dual tank-tracked "heavy-weight" bot.· I am custom building a full aluminum chasis, this bot will carry a 12V (small UPS battery) that might way in the area of 2-4lbs. Down the road, this might need a larger UPS battery, around the 10lb mark.· Now, I need motors, and gearboxes that could move this.· The tread will be custom, not sure what they will be made from yet.
Basicly, I dont know what I should use to move this.· There is a dual motor/gearbox here http://www.robotstore.com/catalog/display.asp?pid=229·that claims, when geared high can put out 941 torque g/cm at·3 volts, (203:1 ratio).· I have no idea if thats enough, or should I be looking for 1500+ g/cm?
Any ideas?
Dave
Any ideas?
Dave
·· I don't think that product will work for you...I've seen it before, and the gears are all plastic.· That's great for bots a little larger than the BOE-Bot, but not by much...And since you're going to be driving tank-treads, you're going to need something stronger.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
The Motor Mind C controller works well with these also.
james
·· Until you have the frame designed and/or built, and know the weight of the tank-treads, you will be hard-pressed to come up with accurate figures as to how much weight you'll be moving, or how much torque will be required to move it.
·· I once built a robot with tank-treads I got from a toy, and although my bot was within the weight specs for the motors, and seemed to be within the torque specs for the motors, I found that driving the tank treads required more torque than driving wheels.
Knight Designs
P.O. Box 97
(607) 535-6777
I am going to start fabbing the aluminum frame this weekend, for reference, this bot will be basicly as large as a large shoebox, but with the 5axis robotic arm, and other stuff like my wireless video cam, the overall weight will quickly shoot up.
Imma model a mock verson what I project it will look like, ill post pics, if anyones interested.. hehe
thanks
dave
Okay, the specs are a little different than I thought...Go to:
www.bgmicro.com (A surplus house)
And select the category MOTORS, and check out part# MOT1011
Knight Designs
P.O. Box 97
(607) 535-6777
Got a general question, I was wondering if a single Motor Mind C, could control 4 DC motors in pair (left/right)
http://www.parallax.com/detail.asp?product_id=30001
Hopefully this weekend ill have my basic frame assembled, and will have a better idea with what I am dealing with.
If the project goes as planned, it will have a robotic arm on its deck, with the ability to pick up, and carry a payload on its upper deck.
I could see this taking months to complete, with my current workload at the office.. but a hobby is a hobby!
[noparse]:)[/noparse]
·· Most of my projects end up taking months, just becauseof the lack of time I have to devote to them all!
Knight Designs
P.O. Box 97
(607) 535-6777
I am interfacing a Analog joystick (Flightstick Pro, 1995) with my javlin, and I· have the X/Y axis working perfectly..
Using http://www.parallax.com/dl/appnt/jav/class/AppnoteAnalogJoystick.PDF· for help, I cannot figure out how to get the buttons working.· The class has support fo buttonX and buttonY, butwhen I run the program, debug says buttonX is not pressed, and Y is always pressed, and no matter what··button I press, nothing changes.· The joystick has 3 buttons onstick, a 4 dir top-hat, and a trigger.
Any ideas?· Is it possible that I need·to change the pins· around from the DB15F on the joystick to other· pins?
Any hints?
Jon Williams wanna jump· in· on this?? :-)
I was looking at those motors on bgmicro, you think 15RPM would be too slow?· The bots chassis (built already) is 16"x12"x5" rectangle 100% aluminum, very light at this point.· Add a 8lb battery (12V battery backup), a few lbs of motors, and tank treads..
I cant find any calculator that can determine speed using tank treads, only wheels.· 4RPM at 3 volts, seems ungodly slow, but I dont know how that translates into treads..
So, if the tracks ran on a 3 inch disc. That would equate to 141 inches per minute, or 2.3" per second. Eek, I need something like 30-50rpm, at that rate. I want the bot to be able to go REALLY slow, but also speed up to about 6-9" per second.
·· There are no constants when working with RPMs alone, in terms of speed...The output shaft may rotate at 15 RPM, but, the speed of the unit will depend on the size of the gear or wheel attached to the shaft.· The gear or wheel, which will be driving the tank treads will affect the speed, based on it's size.· A larger wheel/gear will make the unit move faster.· A smaller one, slower.· So while the RPM is constant, the speed isn't, necessarily.
I hope that helps.· And I was showing you one example of something that could work, I have actually seen many units similar to that one which were metal gearing and enclosures, designed to drive heavier loads than that one you asked about.· Hope that helps!·
Knight Designs
P.O. Box 97
(607) 535-6777
Ill try two, see how good it moves, and if its fast, but lacks power, Ill run 4 of them.
My biggest obstacle at this point is fabbing heavy duty treads.. all toy treads are plastic and small, so it almost has to be completely made from scratch..
·· Remember, 4 motors will draw alot more juice than 2 motors...With the weight you posted, if you can keep the tread weight down, you should be okay, depending on the speed.
Knight Designs
P.O. Box 97
(607) 535-6777
Knight Designs
P.O. Box 97
(607) 535-6777
The body is constructed from 1/8" plastic with solid plastic tread sections held together with steel pins, apparntly it is very suitable to hack, once top shell is removed there is plenty of space. I believe there is a review of one such conversion in the Servo magazine.
If you really want more info I could try and find more details for you.
Sounds like the makings of a cool project.
Regards Nigel
Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Many are cold...
· but few are frozen...
Thank you for the clarifaction, yes that is the model I was referring to, couldn't remember the issue though.
Regards Nigel
Winston Churchill
Knight Designs
P.O. Box 97
(607) 535-6777
this set up can push a kitchen chair...easy...
I think the drive ratio is about 400 to 1.....
hope this helps
Is has two simple hacked servos to move it around...
And of course BS2!!
more pics and videos on this link:
greekbotics.com/robot/forum_viewtopic.php?13.5237.40
