PCA9501 Addressing (Newbie)
·I am having trouble addressing my PCA9501 I/O expander chip.· I can't seem to access the I/O pins.· I have had success with PCF8574A, but no luck with PCA9501.· I'm using the right voltage (3.3v) and pull·up resistors (1.6K)for·SDA and SCL ( as per the data sheet) but I can' get the I/O pins to go low. All addressing pins are grounded.Thanks for any help.
'{$STAMP BS2p}
·X CON 500
·ADDRESS CON %0000000
·MAIN:
·I2COUT 0, ADDRESS,[noparse][[/noparse]%00000000]
·· PAUSE· X
·I2COUT 0, ADDRESS,[noparse][[/noparse]%11111111]
·· PAUSE· X
·GOTO MAIN:
Sid Weaver
Try the Stamp Tester
I2COUT 0, slvAddr, [noparse][[/noparse]%00000000, %00000000]
PAUSE 500
I2COUT 0, slvAddr, [noparse][[/noparse]%11111111, %11111111]
PAUSE 500
The data shee shows a FET between each IO pin and Vss, so I don't think you have to pull the outputs low. In fact, the data shee suggests you pull then high if you're going to use them as inputs.
Jon Williams
Dallas Office
