Re-connect to debug console
If I close the debug window I can't get my BS1 to reconnect at a later time to the debug console without re-downloading the code into the Stamp.
I have tried·re-opening the debug window,·set the Com port, baud·rate, enabled·DTR, and set· N - 8 - OFF. I just get garbage.
How do I reconnect to the debug console·I have disconnected?
Did you close the debug console "gracefully" by use of the console close, or by removing the programming cable? The latter can cause all sorts of problems as much more information is tranferred in the BS-1 debug facilitiy than any of the other Stamps.
Bruce Bates
