D/A 0-10V CTRL for BSII
Hello,
I'm looking for some help (schematic and code) about de way to control a 0-10V frequency motor drive.
If you have some experience in generating 0-10V signals from a BSII, I'm very interested.
If possible without the use of a symetrical power supply.
Thanks in advance !
JR
Thanks in advance !
JR
Jon Williams
Dallas Office
As the power supply of the BSII is about 5V, we can generate analog signals from 0 to 5V with PWM.
I made some tests with succes. But ...
How can we get a drive to generate 0 to 10V ?
I need a amplifier with a gain of 2 (if possible without symetric power supply for the amplifier).
Can you help me with a schematic ?
1) You will need a supply greater than 10V. The more power you try to draw from an opamp the less the maximum voltage will be.
2) They do make rail to rail op amps that don't suffer from this problem. Many can go all the way to the ground rail at least. If this is not true, you'll need a negative supply to get to ground.
3) If you need any current at all, I'd suggest putting a transistor on the output and keeping it in the feedback loop. However, this will give you a .7V offset.
If you look up the LM324 on National's site you can download a data sheet. They have a schematic marked "Power Amplifier" that is what you want except the gain is X10 instead of X2.
The voltage on the - terminal will be Vout*100/(910+100) =Vout*100/1010. However, we know the op amp will try to set the - terminal so that it is the same as the + terminal. We can assume the + terminal draws no current, so the voltage at the + terminal is the same as on the other side of the 91k resistor. So:
V+=Vout*100/1010
V+ * 1010/100 = Vout
V+ * 10.1 = Vout
If you make the two resistors in the - loop the same (say, 250k), then you get:
V+ * 500/250 = Vout
Or 2*V+ = Vout
You'll have to pick a suitable transistor based on your current requirements and compute the head room you need on the power supply. Remember that the transistor cuts 0.6 to 0.7V from the output, so the op amp has to supply 10.7V to get to 10V.
Al Williams
AWC
Kits
http://www.awce.com/kits.htm
I am not absolutely sure but if the transistor is included in the feedback loop,
the 0.7V EB offset should be supressed. OK?
Regards
Al Williams
AWC
For those of you who like Spice, try:
R1 N006 N001 91k
R2 N002 0 250k
R3 N004 N002 250K
Rload 0 N004 100k
Q1 N003 N005 N004 0 2N2222
V1 N003 0 12V
V2 N001 0 5V
X§U1 N002 N006 N005 opamp Aol=100K GBW=10Meg
.model NPN NPN
.model PNP PNP
.lib
.tran .005
.lib opamp.sub
.backanno
.end
Thank you for your expertise !
I wil try this this week-end and hoppely I can give you goed results !
CU
JR
