Bs2 oem
Does the BS2 OEM operate at the same speed as a standard BS2 module - 4000 instructions per second?
Sid Weaver
Try the Stamp Tester
Sid Weaver
Sid Weaver
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
A high resonator frequency would cause both tester readings to be low, as you observed, but 1150 is about 15% lower than the typical value of 1400. That would be way out of tolerance.
A higher than normal threshold would cause one reading to be lower than normal and the other to be higher than normal, which is not what you observed; both were lower than normal.
Check your pulsout readings, to verify the timing there, which should be 2 uS per count.
Is there anything unusual about the wiring, long ground loops, noisy power supply etc.etc?
Tracy Allen
www.emesystems.com
On pins 0-7, high is 1212 to 1382, low 292 to 304.
On pins 8-15, high is 1148 to 1316, low is 280 to 312.
I let it run for a few minutes, then rechecked 8 to 15.· On the high side, 1254 to1440, on the low side 302 to 334.
Maybe it just has to run for a bit to settle down.
Sid Weaver
for x = 1 to 50000
pulsout 15, 1
next
I captured a pulse with my Optascope, zoomed in on it, and got a pulse width of 3us.
Sid
Knight Designs
P.O. Box 97
(607) 535-6777
