how to use debug home ?
hi,
···· lets say i have one program sound like this
···· debug home "L= ",dec5,left_IR
···· what if i want to add another debug line like this
···· debug "beep"
···· will the "beep" overwrite the command above?
···· if yes, what should i do to avoid it?
please teach me, if posible pls show some sample, thanks
···· debug "beep"
DEBUG·HOME,·"L= ", DEC5 left_IR
instead of:
Hope this helps...A complete list of DEBUG commands can be found in the On-Line help files under DEBUG.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Thanks alot for your kindess help, but the keyword "DEBUG BELL" i don't know how to use so would you please help he with some example or pls show me the website to get the info. I have search it ( the help ) by using Google but i can't find it, the nearest results it give me is under this website "http://www.selmaware.com/stampplotlite/HtmlFiles/Hlp_BSAB_Example.htm" and the usage is DEBUG "!BELL".... so i don't know how to use beside, the real thing i want is i wish to add a photoresistor and Infrared into my boebot and detect the reading both at the same time ( there is a break about 20ms between the two device ) so if i set my infrared device to get the latest reading and show it on the terminal and ask the photoresistor to check the environment and display the reading on the screen both together, how to manage it? Lests say my program sound like this
debug home "L = ", DEC5 L_IR, "R = ", DEC5 R_IR
debug home "L = ", DEC5 L_PR, "R = ", DEC5 R_PR
where IR stands for Infrared and PR stands for photoresistor
of course L is left and R is right
if i run the above program, sure the PR value will overide the IR value right? if yes, how to ask it to show both value on the terminal and how to set it? Please help me, thanks.
DEBUG HOME, BELL
DEBUG "L = ", DEC5 L_IR, "R = ", DEC5 R_IR
DEBUG "L = ", DEC5 L_PR, "R = ", DEC5 R_PR
This will home the cursor, beep the PC speaker, print the first line, then print the second line below it...
Knight Designs
P.O. Box 97
(607) 535-6777
