Choosing a board for the Javelin Stamp : The Board of education or the Javelin — Parallax Forums
JoeJoe Posts: 184
edited 2004-09-15 15:19 in General Discussion
I need to choose a board for the Javelin Stamp : The Board of education or the
Javelin Demo Board ?
And , if it is possible, could you tell why ?
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2004-09-08 19:06
    If it is your first javelin, I would order the javelin starter kit
    that includes a javelin demo board. This board has an integrated
    ttl-rs232 level converter chip and SUBD9 female connector which
    is most handy for pc connections. Also includes male/male nullmodem
    adapter, cdrom and programming cable if I am correct.
    Check out the parallax website for it.
    regards peter
  • JoeJoe Posts: 184
    edited 2004-09-08 22:56
    Yes, It is the first Javelin but I have
    a board of education and I would like to know
    if it could be used with the Javeling.
    Any damage problem if I use the Board of edu. ?
    edited 2004-09-09 06:33
    No problem.
    Both javelin and BS have identical pin layout.
    regards peter
  • AllanL5AllanL5 Posts: 12
    Regarding using the BOE with the Javelin.
    Yes, the Javelin will work fine with this board -- however, you should be aware that the Javelin prototyping board has an 'extra' serial port on it.· The reason is that unlike the BS2, where you can use the programming port as a general-purpose comm port to your PC, the Javelin's programming port is dedicated to programming and debugging.
    So, if you use a BOE with it, you'll need to add a MAX-232 chip and capacitors to get a general-purpose comm port for your application.·
    It is theoretically possible to get Parallax to sell you a Javelin prototyping board without a Javelin in it, but the pricing is high.· I went this route myself (using a BOE) and now I regret not having that second Comm port.
