OutOfMemoryError!
· I get this error:
[noparse][[/noparse]Error IDE-0028] Unhandled exception in JVM: java.lang.OutOfMemoryError
Exception thrown in file 'C:\Program Files\Parallax Inc\Javelin Stamp IDE\lib\java\lang\Exception.java' at line 10
The program I have, is for a GPS which is hooked up to the javelin stamp.· I am reading the data in from the GPS and then sending it to a computer, via rs485 protocol.· So when running this program, I get the error mentioned above.· I'm thinking that it's something to do with the buffer or something, and I was wondering if you knew of any command to maybe clear the buffer or something?· I've attached the code to my program.· Let me know if you have questions about it or suggestions to try.· Thanks a bunch for your help!
java
5K
····· while (i<3) {
··· //while (false) {
····· //System.out.print(rsiuart.byteAvailable());
······· if (rsiuart.byteAvailable()) {
········· c=(char) (rsiuart.receiveByte());
········· //System.out.print((int)c);
········· //if (c != 0) {
··········· System.out.println("char: "+(int)c);
··········· i++;
····· CPU.delay(4000);
····· CPU.writePin(flowi,true);
····· txiuart.sendString("<GPS>"+buffer.toString()+"</GPS> ");
····· CPU.writePin(flowi,false);
The above·code will continually execute this line
The use of + to concatenate strings will result in the creation
of temporary strings. As there is no garbage collection it is a matter
of time until you get the out of memory error.
Try to assemble a complete string in a StringBuffer and then use
that buffer to send or print.
regards peter
