interger math question
I've got a MAX186 12-bit A/D converter, which is reading in a voltage from a pot between 0 and 4.096 volts. The pot, which is acting as a tuning knob in my case, only needs to have a total of 82 distinct positions, meaning that a voltage between 0 and 0.05v would correspond to position 1, a voltage between 0.05v and 0.1v would be position 2, etc.
So the A/D will have 50 bits for each of the different positions, so what's the easiest way to read in the bit value (between 0 and 4096) and turn that into a position value (between 1 and 82)? If I simply divide the bit value by 50, I'm left with a floating point number. How can I get just an interger value?
Thanks.
Thanks.
· position = adcVal / 50 + 1
This will give you 1 to·82 across the range of your ADC, like this:
· 4095 / 50 = 81.9 --> BASIC Stamp truncates to 81
· 81 + 1 = 82
Jon Williams
Dallas Office
4050/50 = ·81.0
4055/50 = 81.1
4075/50 = 81.5
4095/50 = 81.9
The Stamp computes all of these as 81.
Instead compute x/5:
4050/5 = 810
4055/5 = 811
4075/5 = 815
4095/5 = 819
Then add 5 and divide by 10. So:
(4050/5+5)/10 = 81
(4055/5+5)/10 = 81
(4075/5+5)/10 = 82
(4095/5+5)/10 = 82
This works nicely because you are dividing by 50. However, if you wanted to use, say 52, you would multiply x by 10 instead (which is OK since 4095 * 10 = 40950 which still fits in a word). So:
(4055*10/52+5)/10 = 78 (should be 77.98 which rounds to 78).
Of course, that being said, a PAK-XII (http://www.awce.com/pak12.htm) makes floating point pretty simple and adds A/D so you can do all your A/D manipulation on the PAK in 32-bit floating point.
Al Williams
AWC
Kits
http://www.awce.com/kits.htm
