DS1302 clock does not run
Looking over the crystal considerations appnote for the DS1302 they mention that the reason why a clock doesn't run might be "the CH (clock halt) or EOSC (enable oscillator) bit has not been set or cleared".
Looking at the code from "StampWorks Experiment #30: Using Real Time Clock",
I·do not see any mention of setting the CH bit. The crystal in use is a citizen which is listed.
Could someone offer advice as to why my clock isn't running?
Anyone have some code which demonstrates this?
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
The code runs as-is without buttons attached and results in descending day/time displaying to debug.
I ripped the circuit apart and re-wired it to no avail. I'm simply trying to set the time without buttons and display it to the debug screen. The clock sits at "Sunday 12:00:00 AM". I'm going to have another look at the code,
I must have missed something.
Post Edited (Jonny555) : 9/5/2004 10:58:45 PM GMT
http://www.parallax.com/dl/docs/prod/appkit/ds1302rtc.pdf show the pin connections like this:
BS2······· DS1302
Pin0<--->Pin7(SCLK)
Pin1<--->Pin6(IO)
Pin2<--->Pin5(RST)
But the stampworks(http://www.parallax.com/dl/docs/books/sw/exp/sw30.pdf) has it setup like this:
Pin0<--->Pin6(IO)
Pin1<--->Pin7(SCLK)
Pin2<--->Pin5(RST)
by switching the pins my clock began advancing on its own...
All this headache over inverted wires lol
Jon
Post Edited (Jonny555) : 9/6/2004 7:28:12 PM GMT
Jon Williams
Dallas Office
Knight Designs
P.O. Box 97
(607) 535-6777
Regards
Klubbsson· (from Sweden)
The attached code is the free code from my Digital Thermostat Prototype.· The attached code runs on a stock BS2, and reads data from a Battery-Backed DS1302 (This code doesn't preset the time) and a DS1620, and displays them on a 20 X 4 LCD Display.· Of course, there are other routines, but everything is well-documented.· If you have any questions, either post them here, or to designs@knightdesigns.com and I will address them.
Knight Designs
P.O. Box 97
(607) 535-6777
That's the main way I connect LCDs to the BS2s...When I have a surplus of pins, I use 4-bit parallel, but the code above uses all SEROUT @ 9600bps.
Knight Designs
P.O. Box 97
(607) 535-6777
But it is a long way to get there for me. I bought the Parralax summer special 3 weeks ago and for the fist time started to learn programming.· So I’m very grateful for all help I can get.
You may, however, need to replace the DS1620 with an ADC0803 and an LM34 or similar so that you can get accurate water temperature.
To be honest I was only offering the code in respect to displaying the time from the DS1302 on an LCD Display, I didn't remember what your original application was.
Good Luck...I will help if I can.
Knight Designs
P.O. Box 97
(607) 535-6777
Post Edited (Orion) : 9/15/2004 1:52:48 AM GMT
