Unknown Unhandeled Exception
I have interfaced the javalin stamp with a vector compass and whenever I run the code for a few seconds...I get unknown unhandled exception...
Can someone please help
regards peter
[noparse][[/noparse] Error IDE-0015] Stack trace is corrupt.
[noparse][[/noparse] Error IDE-0024] Unknown bytecode in the JEM file (dup_x2).
Thanks!
If you need my code, let me know and i will gladly post it.
origin from a static definition but without code I can't tell.
Also, stack trace error: do you use recursive programming (although
that should lead to Out of memory if the recursion never stops).
Can you trace the origin of the error by commenting out the most
recent additions to your code?
trgards peter
I have been tinkering away for the last week prototyping and now am getting similar messages with these two lines...
System.out.print("Extracted var1=");
System.out.println(var1.toString());
where var1 is "static StringBuffer var1 = new StringBuffer(80);"
Messages are...
IDE-0028 Unhandled exception in JVM
IDE-0015 Stack trace is corrupt
IDE-0024 Unknown bytecode in JEM dups_x2
No recursion, 18000 bytes free, nothing reaching their limits.
Since they are debug statements, I have removed them and the problem has gone away.
