Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Caller ID — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Caller ID
DonR
6
2004-09-01 22:39
edited 2004-09-02 05:26
in
BASIC Stamp
Has anyone had any luck with or know of a CALLER ID decoder chip that can be interfaced to a BS2. I don't want a whole modem just the Caller Id info.
Don
ion
101
2004-09-02 03:13
edited 2004-09-02 03:13
http://www.holtek.com.tw/docum/comm/95168.htm
http://www.semiconductors.philips.com/pip/PCD3316T_2.html
http://www.componentvalley.net/rooten/circ_int_logic_1852.html
http://www.repairfaq.org/filipg/LINK/F_CallerID.html
this are few sites to get your info. i used one 15 years ago, made by mitell and worked great.
good luck
ion
DonR
6
2004-09-02 05:26
Thanks for the reply ion.
Holtec
has a 16 pin dip that would be perfect but I can't tell if I would be able to get the timing correct to get the data. SHIFTIN looks like it wants to use it's clock for the timing but the Holtec chip has it's own.
http://www.holtek.com/pdf/comm/9032v140.pdf
The Phillips chip looks good but its in a SO16 package. I haven't successfully done any surface mount projects.
Any Ideas on
the timing with the Holtek Chip
Sign In
Register
to comment.
good luck
ion
Holtec·has a 16 pin dip that would be perfect but I can't tell if I would be able to get the timing correct to get the data. SHIFTIN looks like it wants to use it's clock for the timing but the Holtec chip has it's own.
Any Ideas on·the timing with the Holtek Chip
