BS2
Hi there,
I am henry, i have a problem with my programming. I am now doing a project which interface to the NOKIA 30 Modem which can sent sms using switches.
Eg
Switch 1 is depressed message "Hazel how are u???" will be send out.
Switch 2 is depressed message "Programming is fun..." will be sent out.
but this will work when individual switches are drepressed and individual message will be sent out so when i press switch 1 it will·sent out message 1 only after message 1 sent out then i press switch 2 message 2 will sent out. but when i press switch 1 & 2 at the same time it cannot sent the two message so i wonder is it my programming problem or i need to put the message in que so that it will put the message in que and sent out individually if it sense which switch is depressed 1st. if both switch is depressed it must sent out 2 message so how to do it.
Henry
The Program are as follow:
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
task··········· VAR···· Nib
CHOICE··· VAR·· Byte
Main:
IF IN3 = 1 THEN
DO
ON task GOSUB Task_0
PAUSE 100
LOOP
END
Task_0:
DEBUG "Running Task 0",CR
PAUSE 7000
SEROUT· 2,84,10,[noparse][[/noparse]"at",CR]
PAUSE 2000
SEROUT· 2,84,10,[noparse][[/noparse]"AT+CMGF=1",CR]
PAUSE 2000
SEROUT· 2,84,10,[noparse][[/noparse]"at+csca=",$22,"+6598540020",$22,$2C,"145",CR]
PAUSE 7000
SEROUT· 2,84,10,[noparse][[/noparse]"at+cmgs=",$22,"+6591234567",$22,$2C,"145",CR," Hazel how are u??? ",$1A]
PAUSE 5000
'serout 2,84,10,[noparse]/noparse
'pause· 2000
ENDIF
IF IN4 = 1 THEN
DO
ON task GOSUB Task_1
PAUSE 100
LOOP
END
Task_1:
DEBUG "Running Task 1",CR
HIGH 11
PAUSE 7000
PAUSE 2000
PAUSE 2000
PAUSE 7000
SEROUT· 2,84,10,[noparse][[/noparse]"at+cmgs=",$22,"+6591234567",$22,$2C,"145",CR,"·Programming is fun...·",$1A]
PAUSE 5000
'pause· 2000
ENDIF
GOTO main
Eg
Henry
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
Main:
IF IN3 = 1 THEN
DO
PAUSE 100
LOOP
END
Task_0:
PAUSE 7000
PAUSE 2000
PAUSE 2000
PAUSE 7000
PAUSE 5000
'pause· 2000
ENDIF
IF IN4 = 1 THEN
DO
PAUSE 100
LOOP
END
Task_1:
HIGH 11
PAUSE 7000
PAUSE 2000
PAUSE 2000
PAUSE 7000
PAUSE 5000
'pause· 2000
ENDIF
GOTO main
buttons VAR Nib
Scan:
· buttons.BIT0 = IN3
· buttons.BIT1 = IN4
Main:
· IF (buttons.BIT0) THEN ....
· IF (buttons.BIT1) THEN ....
· GOTO Scan
Jon Williams
Dallas Office
