Question about a weird resistor value
I am in the process of building a stun gun but one of the resistor it uses is a 3k3, I have never heard of a value like that.
I imagine the 3k means 3,000 ohms but was does the other 3 mean, watts? volts? amps?
Im now pretty sure it must mean 3.3k, I looked up really close at one of the pictures and the color bands look to be orange, orange, red, gold which would indicate 3.3k 5% tolerance.
You are correct, this is a 3.3K resistor.
In printed form, this method was adopted to ensure that the decimal point would remain intact through generations of copies,
natural aging, etc. Because the decimal point is such a small character, it is usually one of the first to fade away. By replacing
the decimal point with the unit of measurement this becomes less of a problem. In more modern applications, this method
is used to label bulk or very small devices where the decimal point would be difficult to read in the first place.
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
I worked as a Security Guard for years, and I carried a Pistol.· When I moved to another company, they didn't allow guns, so I got a Stun Gun...Later a Deputy Sheriff I ride mototrcycles with told me that it was illegal (In NY), and recommended I lock it in my safe and leave it there (Which I did).
Just a heads up...I'm sure nobody here is going to turn you in, but you should check.·
P.S. - The 3k3 etc, style is still popular in the UK.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Actually im (and my dad as well) am planning on building a (real) laser as well, I havent decided on what kind yet though. I was thinking of a nitrogen laser but they are prettt much worthless as the beam is invisible (uv I beleive) and they are only about 90 milliwats so no cutting/ burning could be done with one therefore I am now thinking of a co2 laser. While the beam on a co2 laser (IR I believe) is still unvisible they can at least cut/burn stuff.
The answer to your question would be...
YELLOW-PURPLE-GOLD for a 4 Band resistor
YELLOW-PURPLE-BLACK-SILVER for a 5 or 6 Band resistor
Mail Stop GA1
Norcross,GA 30071
Post Edited (Beau Schwabe) : 8/31/2004 6:51:31 AM GMT
A 4.7 ohm resistor is shown as 4R7
Rex Karz
Bakersfield, CA
bugg
Geordi: "It's like the laws of physics went right out the window!"
Q: "And why shouldn't they, they're so inconvenient!"
Geordi LaForge, Chief Engineer, USS Enterprise, NCC 1701-D
Q, Omnipotent Prankster
Oh yeah, and before building a non-visible laser, read up on all precauctions of using them, last thing you want is to get the bright idea·of cutting through some aluminum and have the laser reflecting off and striking you.
· _____·· ROFL, now thats funny!
·V
Post Edited (Paul Baker) : 3/1/2005 10:04:53 PM GMT
DO NOT Look into Laser With remaining Eye
XYZZY...PLUGH...*poof*
Be careful out there.
Sofa
Post Edited (Paul Baker) : 3/2/2005 5:21:06 AM GMT
Lets try this again, if the energy is at 10.6 microns wavelength and the source is coherent, is there a visible component of light spectrum available to to extract with the optics?
I hope I am clear with my question. My ability to communicate my thoughts to paper needs improvement.
Sofa
If there are two wavelengths at the output, then there would be a phase difference dependent upon the difference in wavelength. I do not see that as a problem. I could see some definite applications.
Now if I could just figure out how to write scientific symbols on this forum it would save me some typing. Whats the keyborard shortcut for Lambda?? Weren't we talking about stun guns??
Sofa
