HEAT again
With Respect to my Post HEAT.
I connected a Duracell PP3 9V battery to the connectors that is all.
the chip gets Very hot.
Infact i tried this :-
' HIGH_LOW.BS2
' This simple program sets I/O pin 0 high for 1/2 second and low for
' 1/2 second in an endless loop. Connect an LED to P0 for a simple
' blinker.
' {$STAMP BS2sx}
Main:
HIGH 0
PAUSE 500
LOW 0
PAUSE 500
GOTO Main
END
it downloaded ok ran the program and the little LED flashed for about 5 seconds, then stopped
the chip was so hot, i unplugged the battery.Waited abit and reconnected, No flashy light !!!!!!!
I reconnected to the serial cable COM1 and it recognised the stamp, tokenized it ok but when it went to download said Hardware failure..?
I am sooooooooo STRESSED !!!!!!
' HIGH_LOW.BS2
' blinker.
' {$STAMP BS2sx}
Main:
HIGH 0
PAUSE 500
LOW 0
PAUSE 500
GOTO Main
END
The bad news is sounds like you might have toasted your stamp.....I hope not/
Disconnect everything from your stamp pins.....also sounds like one of your outputs might be unintentionally shorted to ground and sending out 5v?
Can you post the entire program....or was that the entire program?
Ken
Don't get discouraged....the Stamp is an awesome micro.
Ken
This might sound stupid but... get out a magnifying glass and check out your stamp, maybe one of the leads on the interperter IC came loose and is touching another lead. Although if this is the case I doubt you'll be able to fix it yourself, but at least you'll know thats the problem.
Check out the voltage regulator on your stamp as well, maybe a lead on it came on soldered, if the stamp was getting a full 9 volts (rather than the usuall 5) id imagine it would get a bit hotter. You can check and see if its outputting the right voltage by plugging a jumper wire into vss and another into vdd, set your voltmeter to the proper setting and check it out. Be carefull not to touch the jumpers together, thats liable screw up your stamp, or well screw it up more than it already is.
Post Edited (jakjr) : 8/24/2004 5:22:28 AM GMT
Small chance but it could be....
Klaus
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
