IR buddy
I am using IR buddy from http://www.parallax.com/detail.asp?product_id=28016
I use following command to send info 12345678
SEROUT·· IRbSIO,·· IRb96, [noparse][[/noparse]$44, 38,1,2,3,4,5,6,7,8, STR buffer\8]
following is the command to receive the info
SEROUT IRbSIO, IRb96,[noparse][[/noparse]$64]
SERIN·· IRbSIO, IRb96,[noparse][[/noparse] STR buffer\8]
for counter =·0 to 7
debug dec buffer(counter), cr
next
However, when it is receive by another IR buddy
the result is 11345678
any idea why?
next
any idea why?
and give it another try.
Jon Williams
Dallas Office
It did not work.
Jon Williams
Dallas Office
following are code for my program
' {$STAMP BS2}
' {$PBASIC 2.5}
'sent.BS2
buffer VAR Byte
IRbSIO········· PIN···· 14····················· ' IR Buddy serial I/O
IRb96 CON 84+$8000
main :
GOSUB ir_buddy_reset
SEROUT·· IRbSIO,·· IRb96, [noparse][[/noparse]$44, 38, 1, 2, 3, 4, 5, 6, 7, 8]
DEBUG "data sent", CR
PAUSE 500
GOTO main
IR_Buddy_Reset:
· LOW IRbSIO··································· ' signal reset
· PAUSE 5
· INPUT IRbSIO································· ' release reset signal
· PAUSE 50····································· ' allow time for reset actions
· RETURN
' {$STAMP BS2}' {$PBASIC 2.5}'receive.bs2buffer VAR ByteIRbSIO PIN 15 ' IR Buddy serial I/OIRb96 CON 84+$8000c VAR Bytemain :GOSUB IR_Buddy_ResetSEROUT IRbSIO, IRb96,[noparse][[/noparse]$64]buffer(0)=0SERIN IRbSIO, IRb96, [noparse][[/noparse] STR buffer\8]DEBUG "data receive", CRFOR c = 0 TO 7 DEBUG DEC buffer(c)NEXTDEBUG CRtx_wait: IF(INS.LOWBIT(IRbSIO)=0) THEN tx_wait GOTO main IR_Buddy_Reset: LOW IRbSIO ' signal reset PAUSE 5 INPUT IRbSIO ' release reset signal PAUSE 50 ' allow time for reset actions RETURN
The variable named "buffer" needs to be 8 BYTES long, as indicated in the demo programs supplied by Parallax. Therein is the first problem.
Bruce Bates
Jon Williams
Dallas Office
buffer········· VAR···· Byte··················· ' tx-rx buffer (8 bytes)·
cmd············ VAR···· Byte
data1·········· VAR···· Byte
data2·········· VAR···· Byte
data3·········· VAR···· Byte
data4·········· VAR···· Byte
data5·········· VAR···· Byte
chkSum········· VAR···· Byte
I don't see any array from the code.
As to the demo code above, since the BASIC Stamp treats RAM as an array you can get do this:
and you'll get $FF.·· Just to be explicit, here is how the [noparse][[/noparse]implicit] array is organized:
buffer(0) = buffer
buffer(1) = cmd
buffer(2) = data1
buffer(3) = data2
buffer(4) = data3
buffer(5) = data4
buffer(6) = data5
buffer(7) = chkSum
When using the implicit array nature of the BASIC Stamp, you must be very careful of the order of assignments, and make sure that you keep like-sized variables grouped to gether so that you're mindful of the assignment order. The compiler places words first, then bytes, then nibs, finally bits.
Jon Williams
Dallas Office
Post Edited (Jon Williams) : 8/24/2004 6:38:13 AM GMT
