Beginner needs help begining with robotics.
Hi, I'm a rather good coder in Basic, of course I also know some C++, Assembly etc.. and now I'm expanding my field of work to include robotics. So I've found this beginner kit,
and they say "With the addtion of a Basic Stamp BS2 Microcontroller (not included) customized applications can easily be built.", so
if buy the beginner kit and the Basic Stamp would that be all I needed in order to assemble a small robot and code it from my pc? Would I need a wire? Would I need power supply?
Suggestions appreciated.
- Julian
- Julian
There is a Yahoo Group devoted to discussion of this robotic platform using this descriptor:
"tabrobotkit". If you join that group I'm sure you can get all of your questions answered by folks who have already purchased that kit, and before you purchase it.
You can reach that Yahoo Groups area here: http://groups.yahoo.com/group/tabrobotkit/ .
You will need to register with Yahoo to participate, but there is no cost to do so.
Bruce Bates
Julian
This should answer some of your questions and provides some links for further learning:
http://www.robotics.com/robots.html
Bruce Bates
http://www.milinst.com/robotics/robotics.htm#stampbug
It should come assembled already, even if it doesn't I don't need any special tools so I shouldn't have such a hard time making it. Then I have 8 i/o lines extra to add additonal components, and it is fully programable because they say it has "serial programming cable", seems great, except "Uses our School Stamp2 module which may be removed for other projects", whatever they mean by School Stamp2 module, I can buy the Basic Stamp BS2 Microcontroller, and replace it with it right? So I get more appilcation memory, and faster speed? Or doesn't the "servo co-processor" support it?
- Julian
The "School Stamp 2" is apparently their name for the OEM Basic Stamp 2 Kit which is offered by Parallax. You can find a description of that kit here:
http://www.parallax.com/html_pages/products/basicstamps/basic_stamps_oem.asp
Bruce Bates
I would not buy the TAB robot kit, (I did a while ago) because even though you can add a BASIC Stamp 2, the robot is controlled by a lot of commands hardwired into it from the PIC controller.·You can buy a base with servos· ready to add a BS2 from other places, like Budget Robotics, for about the same price.·Then, you· mount a Board of Education with BS2 from Parallax,·download·Parallax's Boe-Bot book free,·and·learn from that (the best place!) the fundamentals of controlling the Bot. Just my opinion.
http://www.budgetrobotics.com/shop/index.php?shop=1&cart=109603&cat=49&
http://www.budgetrobotics.com/shop/index.php?shop=1&cart=109603&cat=35&
Now I don't know how expandable it is, but I'd love to put a sensor on it, and maybe GPS, but GPS in a local condition so I won't have to pay for it, like LPS(Local Position System), so I buy the sender and the receiver. Any ideas?
Thanks.
- Julian
FWIW
I used to be different, but now I'm the same...
