stepper motor wiring
I am trying to wire the mitsumi stepper motor and uln2003a so my bs2x can operate them.· But I see that the stepper motor needs 12 volts and all my power for the stamp is about 5 volts.· Can I just use a 12 volt wall wart or do I need something different for this power?
Also, what ground do I connect the uln2003A to?· Is it the ground for the basic stamp power or the 12 volt power?· And is the common from the ULN2003A 12 volts or 5 volts?
Finally, did I forget anything else?
thanks
bob
thanks
bob
The common for the 2003 is 5volts.· All grounds must be tied together.
Sid Weaver
The Stamp Tester
SID - Where did this 5Volts come from? Was that UNL2003A a typo?
It seems to me that the UNL2?03a can really drive a wide range of steppers or other devices.
Also, www.phanderson.com has a tutorial (tutorial #3) on using the Stamp and the UNL2*03a for steppers.
G. Herzog in Taiwan
Post Edited (Herzog) : 8/23/2004 1:44:34 PM GMT
Docs: http://www.parallax.com/dl/docs/prod/motors/27964.pdf
Jon Williams
Dallas Office
I'm using the Mitsumi motor and ULN2803A & had some of the same questions that the original post mentioned. For the most part, they've been answered, thanks.
Even though I got my circuit to "work", one thing is still bothering me. I happened to use a 9V battery rather than wall wart since I didn't have one in the right voltage range. I attached the positive lead to the "+12V" connection in the circuit and "guessed" that the negative battery lead should be attached to the GND/Vss. Well, the motor works perfectly, but (as I THINK I recall from college physics), the negative terminal of a seat of EMF is not the same as "ground" (?).
So, my questions are:
2. Whether I'm using battery or wall wart, there is always a "+" and "-" terminal of course, or the current wouldn't be able to flow. Why do virtually all circuit diagrams show where to hook up the "+" and (for dummies like me, anyway) not show where the "-" is connected?
Here's my "working" circuit:
Any info would be helpful,
