how to drive 12 Vdc 1 amp motor
what component (and how's the wiring) should i used to drive a 12 Vdc 1 amp motor and
110 or 220·Vac 100 watt from BStamp output (which can turn and off the motor instantly) and without harming the stamp. Thanks
Jon Williams
Dallas Office
SSRs use optically coupled triacs (AC) or transistors (DC) to do the switch, so they are easy do deal with; no mechanical parts, no worry about inductive backlash from a coil.
Jon Williams
Dallas Office
I use a general purpose transistor to drive the relay (see attachment).· I don't use diodes for the 'inductive backlash' because I've never blown a transistor yet.· Yet, I guess it's a good safety feature.
I hope this helps,
Sheldon
1. If the rate of current decay in your relay coil is "slow" (driving transistor turns off "slow") then there will be very little back emf from the relay coil·as· Vinductor = di/dt. So if delta t is long, not much Vinductor.
2. If your relays typically come from salvaged car parts, it is very possible that the relay has either a diode or resistor across the coil.
Many many many years ago,a Japansese·manufacturer (Honda) had diodes intrinsic to relay coils, and that evolved to a resistor in place of the diode. I have not done the math, but if you know the current decay time, and know that it will be consistent, an appropriate value resistor can be used in place of a diode. When you build hundreds of thousands of vehicles a year, multiplied by X number of relays per vehicle, the resistor in place of the diode is a smart cost saving solution.
Ken
Read: http://www.al-williams.com/fetrly.htm
Al Williams
AWC
http://www.awce.com
