Underclocking to match BS2's speed?
Hi.· I have a memory board I want to experiment with.· It's maximum access time from the positive edge of the clock signal is 5.4 ns.· It performs 4,096 cycles per 64 ms.· I know this is fast.· Is there a way to slow this thing down so the basic stamp can use it?· The board is a MC-4532CD647XFA-A75 133MHz (333) 256MB SDRAM DIMM with 16 banks (uPD45128841).· I have the data sheets for both the DIMM and the banks.· I need to know if this CAN be slowed down so the stamp or other microcontroller can use it.· It is externally clocked.· I won't be upset if it can't, but I do want to try.· Thanks.··· Oh yeah.· I know it has 168 pins so not all of it can be used.· I just want to know if the banks can slowed so the stamp can use them.
Is it me or are you looking for all the things a BS2 can't do?
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Knight Designs
P.O. Box 97
(607) 535-6777
Knight Designs
P.O. Box 97
(607) 535-6777
They really help you realized the fundamental planning and fundamental structure of microprocessors.
You could get a small single board computer with lots of memory and a harddisk, but you would likely never come to terms with the basic central issues of concise timing and compact memory use. (I know because I am lazy that way).
The BasicStamp is wonderful as it can communicate, it can control, and it can organize. Usually it can do more than you have time to create. Parallax has an educational attitude that many other tech site seem to ignore.
So be patient, actually do the experiments in the books to build your skills and knowledge, and keep an open mind as new ideas will come. Also, be thankful that technology has moved away from all those parallel lines that DRAM requires for addresses and data -- you really cannot breadboard such devices.
G. Herzog in Taiwan
One, perhaps you should layout your overall design goals...So far (From what I see) it appears as if you are changing your mind/application every other post.· I'm not sure if anyone knows what you're really trying to do.
Two, stop focusing on the limitations of the BS2, and start focusing on what you need for your project.· If you break things down into simpler tasks, maybe it would be easier to achieve your end goal.
If you're trying to do what I see in another forum, then you are definately biting off more than you can chew for a beginner with the BS2, and that may be part of your problem.
For example, instead of trying to build a whole computer (figuratively speaking), work on just the video sub-system first...When we built the car computer, it took two years.· And that was just the electronics.
Knight Designs
P.O. Box 97
(607) 535-6777
