Is this a complete kit?
http://www.parallax.com/detail.asp?product_id=27291
Is this a complete kit?· Will I need to buy anything else besides solder to build it and start programming it?
Can I control servos with it or will I need to buy or make special circuts.
Yes, you can control servos with this module. Download our "What's a Micrcontroller?" text to see how.
Jon Williams
Dallas Office
Usually there is a lot of rosin flux left over and. . .
while the board works, it is not a pretty as wave soldered.
It you want really pretty boards, buy them already wave soldered.
I use rubbing alcohol and an old toothbrush. The alcohol does not mess with the fiberglass circuit board (acetone disolves fiberglass, benzene is a carcinogen, and so is toluene). Mineral spirits may work too, but more smelly.
While acetone and alcohol are reasonably safe, the others can hurt your liver and cause liver cancer if you are really messy and don't wash after using. (House painters get liver problems from paint thinner, so do running shoe assemblers from neoprene glue solvents).· Don't use the bad stuff around infants and small animals.
Be careful and test your solvent before hand as I have removed printed labling from components that tolerate the alcohol, but the lable printing (subminiture relays) does not. Usually ICs, resistors and capacitors are no problem.
G. Herzog in Taiwan
http://www.mgchemicals.com/products/fluxrem.html
413B Heavy Duty Flux Remover
Conductive, flammable,extra strength, may harm some plastics, fast evaporating, ozone safe, low cost.
4140 Flux Remover for PC Boards
Conductive, flammable, safe on plastics, moderate dry time, medium toxicity, low cost.
4141 HFE Super Flux Remover
Excellent cleaning strength, fast Dry, zero residue, non-flammable, non-conductive, non-corrosive, environmentally friendly, test on plastics.
or, you can use solder which has a flux solubil on water , see link below
http://www.kester.com/en-us/products/prodcat_results.aspx?ind=-1&pt=4&chem=19&lf=q
product is
331
Kester "331" Organic Flux is a water soluble formula for use in flux-cored solder wire. This cored solder version of the popular #2331 Neutral Organi
OR-421
Kester “OR421” is a high activity, water soluble, cored wire flux which has been developed as a replacement for Kester “A” flux.
Search Google or your electronic store for place to buy them or call the manufacturer and ask who is the distributor in your area
I am doing soldering from the last 20 years and i can still type with two hands [noparse]:)[/noparse]
Good luck
Ion
Unless you have a very good reason for using this kit, I would recommend buying a normal BS2 as it's too darn easy to ruin components when soldering.
(I wouldn't use an OEM kit unless the stcok version didn't fit physically)
The only thing this kit offers that the stock version doesn't is a D9 connector for the programming cable.
The BS2 is only $4 more, and may even be available in an electronics store closer to you.
Just my opinion.
Jon Williams
Dallas Office
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Unless you're wanting to build it for·specific reason (other than saving·a few·dollars) you might as well just save your self some time (possibly money as well) and just get the preassembled version.
Ill do some practice on some old components and see where Im at, its been awhile and if Im not doing that well Ill send it back or somthing.
