24LC515 Interfacing with BS2sx
Attn:
Jon Williams.
I am having a problem with the 24LC515 EEprom. The problem is that the SX reads the first 32K
but all· information is corrupted in the upper 32K.
I would appreciate any information you can give me. Is it possible the the SX Stamp will not work on
this EEprom with-out special math applied?...
Sincerely yours
J. H. Rollins.
8/17/04
Post Edited By Moderator (shane) : 8/17/2004 4:42:06 PM GMT
Jon Williams.
Sincerely yours
J. H. Rollins.
8/17/04
Since PBASIC gives bit level access, something you could do in your code is this:
This will set the block bit appropriately for the address byte you're wanting to access.
Jon Williams
Dallas Office
Thanks for the information. I have another question on the subject.
my EEprom Code is 10100010 This is the device code.
The first four bits are the control code and the next three A0 A1 A2 are the address A2 is tied to VCC
would this be part of bit three in this addressing. for the· Microchip 24LC515?...
The EEprom is capable of using four EEprom's
on the same bus. Are you saying perhaps that this code would be placed
separately under constants or variables in the program?.
I sincerely appreciate your help.
J. H. Rollins.
http://forums.parallax.com/showthread.php?p=466264
For my new code, plus a demo for the 24LC515 that I think will work for you.· It lets you specify the device address (%00 - %11) as a variable, and takes care of putting the block select bit into the slave address.
Jon Williams
Dallas Office
Thanks for the information on the 24LC515 EEprom. This is a very good example and I am sure that you put a lot of
work in this code. I very much appreciate you help.
Parallax has a great web-site this is much better than Yahoo. In closing I would like to say Parallax has a great application
engineer. Again thank you for your time and talent.
Sincerely yours
J. H. Rollins
congrats Jon , I always read your answers , the most as an spectator but it is always so intesting and well put.
greetings
Francisco
Chile
Jon Williams
Dallas Office
