Data from stamp to PC
I'm an old newbie (renubie?) who has done a couple of stamp/stepper motor projects in the past.· I'm now interfacing a Honeywell ASDX DO pressure sensor with a stamp, using I2C protocol.·
That part of the project is going all right, but I'd·appreciate any advice on how to get data from the stamp into a PC (Excel?).· Am I missing something-is this a done deal or what?
I'm in the hobby mode with this project, so I can't afford hi buck solutions.· Would really appreciate any advice.· Thanks.···· Hermanator
Also, http://www.al-williams.com/npdaqax.htm·works great from Excel or C++ or VB. It is technically made to work with our NetPorter DAQ board, but the download is free for personal use and if you can make your Stamp output strings in the form of:
V1=data
V2=data
Where V1 and V2 are any identifier you want and data is whatever the value you want, then it will work great. For example, you might write:
Temp=33
Level=100
Status=1110011
Al Williams
AWC
Add Floating Point to your Stamp (now with Macros)
http://www.awce.com/pak12.htm
Sorry about misspelling your name. Hermanator
'{$STAMP BS1}
HIGH 5
SYMBOL CS = 0
SYMBOL CSA = 4
SYMBOL AD = PIN1
SYMBOL CLK = 2
SYMBOL data = B0
SYMBOL datb = B6
SYMBOL i = B2
loop:
LOW 5
PAUSE 1
HIGH 5
FOR B4 = 0 TO 39
PAUSE 3000
GOSUB conv ' Get the data from ADC 1.
SEROUT 3,N1200,(B0)
PAUSE 1000
NEXT
FOR B4 = 0 TO 39
'LOW 5
'PAUSE 1
'HIGH 5
PAUSE 3000
GOSUB convt···· ' Get the data from ADC 2.
SEROUT 3,N1200,(B6)
PAUSE 1000
NEXT
SLEEP 3280
GOTO loop
conv: LOW CLK···· ' Put clock line in starting state.
LOW CS
PULSOUT CLK, 1···· ' 10 us clock pulse.
LET data = 0···· ' Clear data.
FOR i = 1 TO 8···· ' Eight data bits.
LET data = data * 2·· ' Perform shift left.
LET data = data + AD·· ' Put bit in LSB of data.
NEXT
HIGH CS
RETURN
convt: LOW CLK···· ' Put clock line in starting state.
LOW CSA
LET datb = 0···· ' Clear data.
LET datb = datb * 2·· ' Perform shift left.
LET datb = datb + AD·· ' Put bit in LSB of data.
NEXT
HIGH CSA
RETURN
***************************************QBasic:
DEFINT A-Z
OPEN "com1:1200,N,8,1,CD0,CS0,DS0,OP0" FOR INPUT AS #1
OPEN "c:\data.log" FOR OUTPUT AS #2
CLS
PRINT "Battery voltage logging (COM1). Press any key to stop."
PRINT "File is located at c:\data.log"
PRINT ""
Again:
temp$ = INPUT$(1, 1)
PRINT ASC(temp$); CHR$(9); DATE$; CHR$(9); TIME$
PRINT #2, ASC(temp$); CHR$(9); DATE$; CHR$(9); TIME$
IF INKEY$ = "" THEN GOTO Again
CLOSE
END
