Can u help me see what is wrong in this code?
The AT commands to read SMS keep repeating. How do i download the program to the BS2p if there is a serin which I believe does not allow the downloading?
thruModem CON 14
toModem CON 15
flowControl CON 13
'Constants''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Baud CON 16624 '8-bit, no-parity, inverted
pauses CON 2000
'Variables''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
serData VAR Byte(9)
GOTO readSMS
readSMS:····· 'Read Message
SEROUT toModem, Baud, [noparse][[/noparse]"AT+CMGR=1",CR,LF]··· 'Read Message = "Shut Down" ' this keeps repeating
DEBUG "AT+CMGR=1"
PAUSE 2000
GOTO a
'SEROUT toModem, Baud, [noparse][[/noparse]CR,LF]
'DEBUG CR,LF
a:
SERIN thruModem\flowControl, Baud,Bad_Data,10000,readSMS, [noparse][[/noparse]WAIT("Shut d"), STR serData\8]·· 'the data is saved in serData as WORD
DEBUG "serData"
GOTO b
Bad_Data:
DEBUG "Parity error",CR,LF
b:
SEROUT toModem, Baud, [noparse][[/noparse]"AT+CMGD=1",CR,LF]···· 'delete message after getting in the data
DEBUG "AT+CMGD=1"
'DEBUG CR,LF
GOTO checking
''''''''''''''''''''''''''''''''something--> Data'''''''''''''''''''''''''''''''''''''''''''''''''''''''
checking:
'IF (serData = true ) THEN shutDown
·GOTO shutDown
shutDown:············ ' Off the Alarm
'sirenPin LOW··········· ' Put Siren to LOW/%00
·GOTO secMessage····· ' Go to reply owner 2nd time
secMessage:············· '2nd msg to owner informing about succesful switching off the alarm
· SEROUT toModem, baud, [noparse][[/noparse]"AT"]
· DEBUG "AT"
· SEROUT toModem, baud, [noparse][[/noparse]CR,LF]
· DEBUG CR,LF
· PAUSE pauses
· SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGF=1"]·········· 'Assign Text Mode
· DEBUG "AT+CMGF=1"
· DEBUG CR,LF···················· ' Carraige Return ot 'Enter'
· PAUSE pauses
· 'AT+CMGS=90225042[noparse][[/noparse]ENTER]
· SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGS"]············ 'Send 2nd Message to Owner
· DEBUG "AT+CMGS"
· SEROUT toModem, baud, [noparse][[/noparse]61]
· DEBUG 61····································· 'ASCII Equivalent for =
· SEROUT toModem, baud, [noparse][[/noparse]"90225042"]············ 'Liling's number
· DEBUG "91918287"······························ 'dest(Liling) mobile no
· DEBUG CR,LF
· PAUSE pauses
· '>MSG^Z
· SEROUT toModem, baud, [noparse][[/noparse]"Alarm Off Successful"]·········· 'MSG Successful.
· DEBUG "Alarm off Successful"···························· 'msg
· SEROUT toModem, baud, [noparse][[/noparse]26]
· DEBUG 26
· PAUSE pauses
I need all ya guidance Masters. [noparse]:)[/noparse]
thruModem CON 14
toModem CON 15
flowControl CON 13
pauses CON 2000
serData VAR Byte(9)
GOTO readSMS
DEBUG "AT+CMGR=1"
PAUSE 2000
GOTO a
'DEBUG CR,LF
a:
DEBUG "serData"
GOTO b
Bad_Data:
b:
DEBUG "AT+CMGD=1"
'DEBUG CR,LF
GOTO checking
checking:
·GOTO shutDown
· DEBUG "AT"
· DEBUG CR,LF
· PAUSE pauses
· DEBUG "AT+CMGF=1"
· PAUSE pauses
· DEBUG "AT+CMGS"
· DEBUG CR,LF
· PAUSE pauses
· '>MSG^Z
· DEBUG 26
· PAUSE pauses
Jon Williams
Dallas Office
Post Edited (Jon Williams) : 8/16/2004 1:19:11 AM GMT
Pin 15 to modem pin 2, Pin 14 to modem pin 3, pin 13 to modem pin4(dtr)and VSS to modem pin 5.
The 4 wires are going to the bread board. The serial port of BS2p will be used to download the program to it.
How do i attach the ATN from the breadboard to the modem DTR which i have already reserve it for serin for flow control.
Post Edited (ice-egoz) : 8/16/2004 3:04:06 AM GMT
thru the serin/serout pins using the standard stamp to PC cable.
You send an "AT" command to the modem, but pause 2000 (2 seconds) before
you go read the reply. The stamp family has no means to buffer serial input
data, so by the time you go to read the reply, the data has come and gone.
Try removing the 2 second pause between the send to modem and the recieve
from modem.
hope this helps,
Dennis
My best suggestion, as your code is getting a bit convoluted, is to remove everything (via comments), and start to add things back in, testing as you go.·
Jon Williams
Dallas Office
My code:
' {$STAMP BS2p}
' {$PBASIC 2.5}
toModem CON 15
thruMOdem CON 14
flowControl CON 13
baud CON 16624
serData VAR Byte(9)
GOSUB readSMS
GOSUB seeData
'GOSUB checking
'GOSUB shutDown
'GOSUB secMessage ' Go to reply owner 2nd time
readSMS:
DEBUG "AT"
SEROUT toModem,baud, [noparse][[/noparse]CR,LF]
DEBUG CR,LF
PAUSE 2000
'Making sure that the GSM module is in text mode.
SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGF"]
DEBUG "AT+CMGF"
DEBUG 61 'ASCII Equivalent for =
SEROUT toModem, baud, [noparse][[/noparse]"1"]
DEBUG "1"
DEBUG CR,LF ' Carraige Return ot 'Enter'
PAUSE 1000
SEROUT toModem,baud, [noparse][[/noparse]"AT+CMGR"]
DEBUG "AT+CMGR"
DEBUG 61
DEBUG "1"
DEBUG CR,LF
'PAUSE 200
seeData:
'SERIN thruModem, baud, [noparse][[/noparse]STR serData\8]
'SERIN thruModem, baud, [noparse][[/noparse]WAIT("Shut d"), STR serData\8]
'SERIN thruModem\flowControl,baud,Bad_Data,25000,readSMS, [noparse][[/noparse]WAIT("Shut d"), STR serData\8] 'the data is saved in serData as WORD
SERIN thruModem,baud,Bad_Data,25000,readSMS, [noparse][[/noparse]WAIT("Shut d"), STR serData\8] 'the data is saved in serData as WORD
DEBUG serData
Bad_Data:
GOTO checking
'SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGD=1"] 'delete message after getting in the data
'DEBUG "AT+CMGD=1"
'SEROUT toModem, baud, [noparse][[/noparse]CR,LF]
'DEBUG CR,LF
checking:
GOTO shutDown
shutDown: ' Off the Alarm
'sirenPin LOW ' Put Siren to LOW/%00
GOTO secMessage
secMessage: '2nd msg to owner informing about succesful switching off the alarm
DEBUG "AT"
DEBUG CR,LF
PAUSE 2000
SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGF=1"] 'Assign Text Mode
DEBUG "AT+CMGF=1"
PAUSE 2000
SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGS"] 'Send 2nd Message to Owner
DEBUG "AT+CMGS"
SEROUT toModem, baud, [noparse][[/noparse]"90225042"] 'Liling's number
DEBUG "90225042" 'dest(Liling) mobile no
DEBUG CR,LF
PAUSE 2000
'>MSG^Z
SEROUT toModem, baud, [noparse][[/noparse]"Alarm Off Successful"] 'MSG Successful.
DEBUG "Alarm off Successful" 'msg
DEBUG 26
PAUSE 2000
