Surface mount Vs. lead mount. Which is better?
Hewwo, all.· First I want to thank all the peole who have helped me out thus far.· I have just aquired a PCB layout software and am going to design and order a·custom board.· I have been told by several buddies and a few companies that I would find it better for my robotics apps if I used surface mount components instead of lead mount.· I can see how this would be true sinse surface mountable components are usually smaller, but what is the difficulty level of setting suface mount components on a PCB?· Also, way off topic, has anyone ever confronted a robotics type circuit with an actual PC DIMM RAM chip on it?· Like what comes out of a PC?· I read a book where they talked about such a thing.· Could this be possible or is the memory addressing just too much for a small controller to handle?· Thankies!· =^.^=
in fact, heres a link to that kit http://www.apogeekits.com/smiley_face.htm
As far as pro's/con's go, all you'll gain by using SMD's is a smaller/lighter board and a headache from straining youre eyes soldering them·
As far as being hard to solder, Id rate 'em on a scale of 1 to 10 (10 being the hardest) a 7 or a 4. 7 using a regular soldering iron and no magnifacation,·4 using and iron with a very fine point tip and a magnifier.
If you use some tweezers, a magnifier of some sort, and a nice fine point soldering iron (I prefer butane and of the ~80 watt equivalent range)·its not too too hard. The main thing is you need to be patient, and you need to take some breaks so your eyes can recooperate.
It will also depend on what type of components you'll be soldering, generally stuff like resistors/diodes etc.·arent too hard to work with but stuff that looks like a centepede is where wou might have trouble.
Post Edited (jakjr) : 8/14/2004 8:47:54 AM GMT
Sid Weaver
USB-powered Stamp Board
Some PCB production services have the 'hole count' as a factor in the price.
(Drilling them takes time and effort)
And doing it manually is a pain in the posterior.
(Somehow, there's always one or two holes out of alignment with the others when you're drilling holes for a 40 pin IC.)
I have in my extensive collection a Sharp computer where the chips have had their pins bent outwards so that they could be surface-mounted.
In a RAMDisk for another computer (an Epson PX-4) they've soldered in one RAM chip using through-hole pins, then they've 'piggy-backed' 3 more on top of that one(soldering it in pin-to-pin) with just the Chip-Select pins bent out and with individual wires soldered to them.
You could even cut a hole the size of the IC and have solder pads around the edges, then bend out the pins of the IC and have it 'sunk' into the PCB if you want a thinner result.
(I can't remember seeing it done with IC's, only caps and Xtals)
Dr. Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
