E2PROM Interface? — Parallax Forums
E2PROM Interface?
HopsHops Posts: 7
edited 2004-08-14 19:41 in BASIC Stamp
My brother had a buch of stored IC and I cam across
X2816CP-20
16K (2048 x 8bit)
5 Volt
Byte alterable E2PROM
I would like to find a datasheet for it but to do that I need to register for nearly $100, but if anybody here had any experience with interfacing an E2PROM to a BS2, or could obtain a datasheet for me, let me know
-Jeff
  • jakjrjakjr Posts: 88
    edited 2004-08-12 17:24
    Ive seen simular things for sale at "Fry's electronics" you might have a look on their website (outpost.com) although I doubt there will be anything on there seeing as they dont even list IC's on the website.
  • Buck RogersBuck Rogers Posts: 2,212
    edited 2004-08-12 19:46
    Hello from GCL better known as Buck Rogers
    Also try Xicor, that's one of their E2EPROM chips. Try www.xicor.com , it also might be made by a different company as well. Try running that part number through the Google search engine. Ignroe those sites that demand you pay to register.
    In fact I have one here, but its not made by Xicor. But I can't remember its company name.
    GCL hansolofalcon@att.net
  • HopsHops Posts: 7
    edited 2004-08-13 21:04
    Found the data sheet [noparse]:)[/noparse]
    DESCRIPTION
    The Xicor X2816C is a 2K x 8 E2PROM, fabricated with
    an advanced, high performance N-channel floating gate
    MOS technology. Like all Xicor Programmable nonvolatile
    memories it is a 5V only device. The X2816C
    features the JEDEC approved pinout for byte-wide
    memories, compatible with industry standard RAMs,
    ROMs and EPROMs.
    The X2816C supports a 16-byte page write operation,
    typically providing a 300ms/byte write cycle, enabling the
    entire memory to be written in less than 640ms. The
    X2816C also features DATA Polling, a system software
    support scheme used to indicate the early completion of
    a write cycle.
    Xicor E2PROMs are designed and tested for applications
    requiring extended endurance. Inherent data retention
    is greater than 100 years.
    FEATURES
    • 90ns Access Time
    • Simple Byte and Page Write
    —Single 5V Supply
    —No External High Voltages or VPP ControlCircuits
    —Self-Timed
    —No Erase Before Write
    —No Complex Programming Algorithms
    —No Overerase Problem
    • High Performance Advanced NMOS Technology
    • Fast Write Cycle Times
    —16 Byte Page Write Operation
    —Byte or Page Write Cycle: 5ms Typical
    —Complete Memory Rewrite: 640ms Typical
    —Effective Byte Write Cycle Time: 300ms
    Typical
    • DATA Polling
    —Allows User to Minimize Write Cycle Time
    • JEDEC Approved Byte-Wide Pinout
    • High Reliability
    —Endurance: 10,000 Cycles
    —Data Retention: 100 Years
    It also gives the more technical lowdown on all of the features.
    Anybody have any links that would help me interface this?
  • HopsHops Posts: 7
    edited 2004-08-14 00:11
    Is there a difference between interfacing an EEPROM as opposed to an E2PROM (what's the difference)??
  • SPENCESPENCE Posts: 204
    edited 2004-08-14 01:06
    Excuse the caps.
    The xicor is parallel interface with direct parallel addressing so it would be a major job to make it work with a serial interface.
    Spence
    edited 2004-08-14 03:03
    Not to change the subject but... whats the deal with all caps? even your username is in all caps, is your keyboard messed up or something?
  • HopsHops Posts: 7
    edited 2004-08-14 03:28
    SPENCE - thanks
    edited 2004-08-14 14:54
    jakjr said...
    He has trouble reading the lower case characters...I think everyone's gotten used to it by now from the Yahoo Group.
    Knight Designs
    324 West Main Street
    P.O. Box 97
    Montour Falls, NY 14865
    (607) 535-6777
    Business Page:·· http://www.knightdesigns.com
    Personal Page:··· http://www.lightlink.com/dream/chris
  • BillboyBillboy Posts: 5
    edited 2004-08-14 18:26
    Jeff (HOPS),
    For future reference, you can use www.partminer.com to look up parts and you do not have to pay to register. I have an account that will allow me to find parts from the part number listed on the package. This is an excellent website to research IC's and discrete (JFET's, Bipolar's, etc.).
    Bill, KC9CFO
    Chris Savage said...
    jakjr said...
    I see, I thought maybe his keyboard was messed up. I used my old keyboard so much that the space bar wore out (and most of the lettering wore off as well), you about had to hit it with a sledge hammer to get it to work lol.gif .
