receiving SMS from the Wavecom and the BS2p supposedly receives the SMS.
Hi. U must have figured out that adila and me are in the same group.
Hi. Her's was the sending of SMS, mine's the receiving of a reply message-> 'Shut Down'
So for me, I shud use the AT-commands--> "AT+CMGR=1"
serout 13,9600,[noparse][[/noparse]AT+CMGR=1]·· ' is this able to read the sms? and the readings> done in BS2p/modem?
·········································· ' know that commands are sent to the modem, so the data is·opened in the ·········································· 'modem? lets say that the message is "Shut Down". I need to extract that
········································· ·'message. so how do i go abt extracting? I need to use that message to do some
···········································'comparing in the BS2p.
output wud probably look like this-->
+CMGR: “REC UNREAD”,”0146290800”,
”98/10/01,18 :22 :11+00”,<CR><LF>
Shut Down
I doubt that the wiring is a problem over here, cos Im using the Pins 14 and 13. Pin 13 will be to receive the message. Pin 14 will be to send out the AT-commands.
I need all ya guidance Masters. [noparse]:)[/noparse]
Shut Down
Please try this. It works for me.
SMSMsg VAR Byte(9)
readsms:
serout 13,9600,[noparse][[/noparse]"AT+CMGR=1",CR,LF] ' read sms stored on index 1
pause 1000 ' giv the modem time to think.....
SERIN 14, 9600,Bad_Data,65000,readsms , [noparse][[/noparse]WAIT("Shut d" ), STR SMSmsg\8 ] ' listen on pin 14 until "Shut d" is recived. if not received within 10 seconds it tryes again.
' a sms with the text "Shut d" is received.
serout 13,9600,[noparse][[/noparse]"AT+CMGD=1",CR,LF] ' delete sms stored on index 1 (if the sms is not deleted the next sms comming wil be stored in index 2 and so on)
goto readsms ' wait for a new SMS
Bad_Data:
DEBUG "Parity error",CR,LF
//akj
checking:
IF (SMSMsg = "Shut Down") THEN shutDown················· ' does this comparison works?
shutDown:············ ' Off the Alarm
'sirenPin LOW··········· ' Put Siren to LOW/%00
·GOTO secMessage····· ' Go to reply owner 2nd time
secMessage:············· '2nd msg to owner informing about succesful switching off the alarm
· SEROUT toModem, baud, [noparse][[/noparse]"AT"]
· DEBUG "AT"
· SEROUT toModem, baud, [noparse][[/noparse]CR,LF]
· DEBUG CR,LF
· PAUSE pauses
· SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGF=1"]·········· 'Assign Text Mode
· DEBUG "AT+CMGF=1"
· DEBUG CR,LF···················· ' Carraige Return ot 'Enter'
· PAUSE pauses
· 'AT+CMGS=90225042[noparse][[/noparse]ENTER]
· SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGS"]············ 'Send 2nd Message to Owner
· DEBUG "AT+CMGS"
· SEROUT toModem, baud, [noparse][[/noparse]61]
· DEBUG 61····································· 'ASCII Equivalent for =
· SEROUT toModem, baud, [noparse][[/noparse]"91918287"]············ 'Liling's number
· DEBUG "91918287"······························ 'dest(Liling) mobile no
· DEBUG CR,LF
· PAUSE pauses
· '>MSG^Z
· SEROUT toModem, baud, [noparse][[/noparse]"Alarm Off Successful"]·········· 'MSG Successful.
· DEBUG "Alarm off Successful"···························· 'msg
· SEROUT toModem, baud, [noparse][[/noparse]26]
· DEBUG 26
· PAUSE pauses
Let me explain this againg:
debug "wait for shutdown",cr,lf
SERIN 14, 9600,Bad_Data,25000,readsms , [noparse][[/noparse]WAIT("Shut d" ), STR SMSmsg\8 ]
debug "Shutdown received from modem",cr,lf
Above statement listens on pin 14, 9600 baud.
The wait statement tells the SERIN command not to continue before the text "Shut d" is received. (Wait statement can only have 6 chars, therefore onle "Shut d" and not "Shut down).
If SERIN not receives a string within 10 seconds it goes to the "funktion" readsms (se example in my first post)
Debug output will now be:
wait for shutdown
wait for shutdown
wait for shutdown
wait for shutdown
wait for shutdown
In this way you dont have to compare strings, The SERIN command does it all for you.
//akj
IF (SMSMsg="Shut Down") THEN secMsg
You don't understand me.....
1: readsms:
2:
3: ' read sms index 1
4: SEROUT toModem, baud, [noparse][[/noparse]"AT+CMGR=1",CR,LF]
5:
6: ' give the modem time to think
7: pause 1000
8:
9: debug "wait for shutdown",cr,lf
10: SERIN 14, 9600,Bad_Data,25000,readsms , [noparse][[/noparse]WAIT("Shut d" ), STR SMSmsg\8 ]
11:
12: debug "Shutdown received from modem",cr,lf
13: gosub DoWhatTo
This is all you need, you will never reach line 12 if the text "Shut d" is not received from the modem.
Have you tried the code ??
//akj
And for above i need to check the string. what if there are missing spaces or the alphabets are wrongly capitalised? does this affect for going to gosub?
thruModem CON 14
toModem CON 15
flowControl CON 13
'Constants''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Baud CON 16624 '8-bit, no-parity, inverted
pauses CON 2000
'Variables''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
serData VAR Byte(9)
GOTO readSMS
readSMS:····· 'Read Message
SEROUT toModem, Baud, [noparse][[/noparse]"AT+CMGR=1",CR,LF]··· 'Read Message = "Shut Down"
DEBUG "AT+CMGR=1"
PAUSE 2000
'SEROUT toModem, Baud, [noparse][[/noparse]CR,LF]
'DEBUG CR,LF
SERIN thruModem\flowControl, Baud,Bad_Data,10000,readSMS, [noparse][[/noparse]WAIT("Shut d"), STR serData\8]·· 'the data is saved in serData as WORD
DEBUG "serData"
Bad_Data:
SEROUT toModem, Baud, [noparse][[/noparse]"AT+CMGD=1",CR,LF]···· 'delete message after getting in the data
DEBUG "AT+CMGD=1"
'DEBUG CR,LF
GOTO checking
''''''''''''''''''''''''''''''''something--> Data'''''''''''''''''''''''''''''''''''''''''''''''''''''''
checking:
'IF (serData = true ) THEN shutDown
·GOTO shutDown
· DEBUG "AT"
· DEBUG CR,LF
· PAUSE pauses
· DEBUG "AT+CMGF=1"
· PAUSE pauses
· DEBUG "AT+CMGS"
· SEROUT toModem, baud, [noparse][[/noparse]"90225042"]············ 'Liling's number
· DEBUG CR,LF
· PAUSE pauses
· '>MSG^Z
· DEBUG 26
· PAUSE pauses
