rechargable light-weighted batteries for 2p40
··· Does anyone know any rechargable batteries (along with the recharger or recharging-circuit) that I can use to run a 2p40 along with two typical IC's and 2 LEDs? I need it to be light-weight (less then 20 grams).
They weigh about 20 grams (5 cell pack) and are 150mAh NiMh cells. They can be charged using a trickle charger outputting 15mA... normal charge time is 18 hours at this rate.
Since the voltage regulator would like as close to 5.5 volts as possible because it throws off more heat, I am happier with this than a 9volt cell and it weights less than 4 AA cells - plus much more output
