BASIC Stamp2p24: Does it come with integrated UARTs or does it tout serial comm
Hi, My project requires 2 hardwares{GSM modem and GPS receiver} to be integrated to the BS2p24.
I know that I need to use the MAX chip {MAX238CNG}. I know that it is a level convertor. So does the BS2p24 has UART? Or do I even need UART? My part of the project is to come out with 2 serial ports using the MAX chip. So that the GSM modem and GPS receiver can be integrated to the BASIC Stamp. I know I need to do cabling but i want to check whether whatever I have·typed makes sense or not. I do need capacitors but do i have a certain criteria for choosing one? How about resistors? Do I need them?
"OIOOIOOO OIIOOIOI OIIOIIOO OIIOIIOO OIIOIIII OOIOOOOO OIIIOIII OIIOIIII OIIIOOIO OIIOIIOO OIIOOIOO OOIOOOOI"
I need all ya guidance Masters. [noparse]:)[/noparse]
Suppose you have 2 GPS receivers connected to the Stamp so that they send data out every second. The physical connection is not a problem. But the Stamp can only listen to one at a time. If the Stamp is listinening to GPS "A" when GPS "B" sends its data, that data is lost. If the Stamp is doing something else while either GPS sends data, you lose data. There is no buffer. In some cases, you can use hardware handshaking to mitigate this problem (but that costs I/O pins, of course). There are also some "UART/buffer" chips that will work (see http://www.wd5gnr.com/suart.htm).
So there isn't a simple answer. Yes, the Stamp can do many serial channels with the addition of a level converter (see http://www.awce.com/rs1.htm). But it takes planning in software since the serial channels are software-only and have no buffering. Even handshaking can have problems since most devices don't react instantly to handshaking.
We've often considered making an "RS232 coprocessor" for the Stamp, but I've never been completely sure what feature set it would have. The MAX3110 chips come close and have level conversion onboard but they are expensive and somewhat hard to get.
Good luck!
Al Williams
AWC
Stamp Prototyping Board
http://www.awce.com/asp3.htm
'{$STAMP BS2p}
· PAUSE 250
· DEBUG "AT+IFC"······························· 'do I NEED TO SPECIFY WHETHER THE MODEM IS HARDWARE?
· DEBUG 61
· DEBUG "0,0"
· DEBUG CR
· PAUSE 2000
· DEBUG "AT"
· DEBUG CR
· PAUSE 2000
· DEBUG "AT+CSCA"···················· ·'this is the SMSC number of the SIM card inside the modem
· DEBUG 61
· DEBUG "98540020"
· DEBUG CR
· PAUSE 3000
· DEBUG "AT+CMGF"·············· 'Making sure that the GSM module is in text mode.
· DEBUG 61······················ 'ASCII Equivalent for =
· DEBUG "1"
· DEBUG CR···················· ' Carraige Return ot 'Enter'
· PAUSE 3000
· DEBUG "AT+CMGS"········· 'this is to send·an SMS
· DEBUG "+6597375633"
· DEBUG CR
· PAUSE 4000
· DEBUG "KOPILA HERE"
· DEBUG 26·················· 'equivalent to ctrl-z, to end
· DEBUG CR
· PAUSE 2000
END
Will this even work? do i have to worry abt the electronics part? The power supply?
