Can the Stamp act as a IR Remote — Parallax Forums
JackPollackJackPollack Posts: 8
edited 2004-08-06 01:26 in BASIC Stamp
I am a Stamp newbie and don't know if this is possible, or complicated.
I need to build a circuit that will recive about 20 differant IR codes from one remote control, and then·broadcast one·20 recriprical IR commands.
Is this possible with the Stamp? Should I use the IR buddy or something else.
Any help or info would be greatly appreciated, since as mentiond earlier, this is all new to me.
  • jakjrjakjr Posts: 88
    edited 2004-08-02 03:31
    I was wondering the same thing. I just bought a infared LED and was wanting to use it to make an IR tv remote using my BOE board and BS2 stamp.
    I just need to send 16 codes though, 0-9 volume up/down channel up/down and power on/off.
    By the way im a newb too so if somone replys please explain it in newbmans terms.
  • NewzedNewzed Posts: 2,503
    edited 2004-08-02 12:37
    This can be accomplished with a Sony TV remote.· The remote can transmit about 30 separate signals which are easily decoded by the Stamp.· Sending an IR signal from the Stamp frequires some additional circuitry on the Stamp.
    As an alternative, take a look at our TWS/RWS system.· Simple to install, uses serin and serout.
    Sid Weaver
    check out our 4-digit serial LED
  • poguemomhoinpoguemomhoin Posts: 13
    edited 2004-08-02 12:43
    Check out the following article, very good (as always)
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv76.pdf
  • macmanmacman Posts: 20
    edited 2004-08-02 15:50
    I have also been toyng with the idea of using an IR Remote for control of a BoeBot. Johnathon Peakall has a very neat unit that can be built for very little cash here is the link http://madlabs.info/ir_remote.shtml
    I found it very useful so thought maybe it might help you guys also.
    Regards Nigel
    edited 2004-08-03 18:26
    Nigel,
    Parallax is on the brink of releasing a 150-page educational tutorial on infrared communication. This text shows the ins and outs of decoding the Sony infrared remote control. It does not demonstrate how to mimic an infrared remote control, however. If our customers like you make this request we will also add the 555 timer and parts to do this in the next revision.
    Sincerely,
    edited 2004-08-03 20:48
    Jack,
    In the meantime, try this: http://www.parallax.com/dl/docs/prod/compshop/tvremote.pdf which also demonstrates Stamp to Stamp communication via infrared. See the last couple of pages in this document which demonstrate send/receive with pulse width modulation.
    edited 2004-08-03 21:54
    YES Please.
    Ken Gracey (Parallax) said...
    Nigel,
    Sincerely,
    Yes please add the 555 timer info.
    Post Edited (jakjr) : 8/10/2004 8:22:57 PM GMT
