Zero Crossing Detection
Hasan
With background in CS, I have been working with enterprise Java for the past five or so years. Now I am getting back into my true passion, hardware design and Micro Java (MIDP). I came accross Javlin and bought the starter kit immediately.
After going through the manual, as my first project, I wanted to build a home control system based on Javlin and X10 protocol. I wanted to base my design on the ideas in application notes by Microchip, "Interfacing to AC Powerl LInes" and "X10 Home Automation Using the PIC16F877A". PIC can be made to detect zero crossing by connecting AC line directly to an I/O pin (thru and resistor). The input proectection diodes at the pin also do the voltage limiting. PIC can, then detect the edges and so the zero crossing. This is brilliant because only one external passive component is needed.
Now the question is, does Javelin have the protection diodes at its input pins? Can I do the same type of simple design to detect zero crossing with Javelin? The manual I have doesn't give this kind of specs. I could use the ADC VP too but I liked PIC's approach better.
Thanks for any help.
-Hasan
-Hasan
Jon Williams
Dallas Office
Russ
