Noritake VFD display
I was using a BPI-216 serial display from Seetron and I switched to a VFD display from Noritake.· It's a serial display, 1X14, and runs at 9600.· Does anyone know where I can find sample codes to get this thing to work?
Chris
Chris
Might have to change your baud rate.
Have you already interfaced the BPI display?
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
I kind of thought I would have this problem so I just wrote a simple code to say "hello" with the BPI, made sure it worked and then took the Noritake and tried it.· This is a brand new display but I was hoping it worked like thier other displays.·
you might want to check your baud rate as a quick start!
Steve
