Can someone help me shorten this code up pls?
· This code works fine, but I know it could be shorter using select case or something (which I can't make my braincell fit around). Could someone run over this and explain to me what I can do to make it shorter and sweeter please?
· The program uses an LTC 1298 adc to read x/y axis of joystick, then sends control bytes out a Surelink to the Bot.
·Thanks
'{$STAMP BS2}
'{$PBASIC 2.5}
' Program: JoeControlBoard.BS2 (LTC1298 analog-to-digital converter,Surelink)
' Transmits via Surelink 2 direction control bytes to bot derived from adc hooked up to joystick.
' The transmitter side should be running JoeControlBoard.BS2.
' Receiver/Tranmitter should be running Transceiver1.BS2.
' Receiver should be running SerialReceiver1.BS2
' Set up Program Variables and Constants
config······· VAR··· Nib················ ·' Configuration bits for ADC.
startB······ ·VAR··· config.BIT0····· ·' Start bit for comm with ADC.
sglDif······· ·VAR··· config.BIT1······ ' Single-ended or differential mode.
oddSign····· VAR··· config.BIT2······ ' Channel selection.
msbf········ ·VAR··· config.BIT3····· ·' Output 0s after data xfer complete.
Value········ VAR··· Word·············· ' Variable to hold 12-bit AD result.
ValueBit···· ·VAR··· Value.BIT0
Idx············ VAR··· Byte
baud··········CON··· $4054········· ·· ' lcd baud
sbaud······· ·CON··· $4054········· ·· ' Baudrate for Surelink
Dout········· ·CON··· 0················· ·' Data out to Surelink
Din·········· · CON··· 1················· ·' Data in from Surelink
Link·········· ·CON··· 2················· ·' Surelink link indicator
Tx············ ·CON··· 8
lcd··········· ·CON··· 9
CS············ CON··· 13··········· ·· · ' Chip select; 0 = active
CLK········· · CON··· 14·············· · ' Clock to ADC; out on rising, in on falling edge.
DIO_n······· ·CON··· 15··············· ·' Data I/O pin _number_.
' Initialize
SEROUT lcd,baud,[noparse][[/noparse]12,14,"JoeControlBoard"]
PAUSE 2000
SEROUT lcd,baud,[noparse][[/noparse]12,"Ch0:",13,"Ch1:"]
HIGH Dout
GOSUB Chklink
' Main
HIGH CS·································· ·· ' Deactivate ADC to begin.
HIGH DIO_n································· ' Set data pin for first start bit.
main:
··· oddSign = 0··························· ·· ' channel 0
··· GOSUB convert························· ' Get data from ADC.
··· GOSUB Assign0························· ' Make into a byte
··· GOSUB Transmit························ ' Send
··· SEROUT lcd,baud,[noparse][[/noparse]16,69,18,5,DEC4 Value]
··· oddsign = 1····························· ·' channel 1
··· GOSUB Assign1························· ' Make into a byte
··· GOSUB Transmit1······················· ' Send
··· SEROUT lcd,baud,[noparse][[/noparse]16,85,18,5,DEC4 Value]
GOTO main·································· ·' Endless loop.
'···················· ADC Subroutine
convert:
· config = config | %1011························· ' Set all bits except oddSign.
· LOW CS············································· ··' Activate the ADC.
· SHIFTOUT DIO_n,CLK,LSBFIRST,[noparse][[/noparse]config\4]· ' Send config bits.
· SHIFTIN DIO_n,CLK,MSBPOST,[noparse][[/noparse]Value\12]··· ' Get data bits.
· HIGH CS············································· ·' Deactivate the ADC.
·RETURN··············································· ·' Return to program.
' Transmit Routine for Surelink
Transmit:
·SEROUT Dout,sbaud,[noparse][[/noparse]"x",value]··········· ' Out to Surelink
RETURN·········································· ·' Send "x" first to sync with receiver, then data
Transmit1:
·SEROUT Dout,sbaud,[noparse][[/noparse]"y",value]··········· ' Out to Surelink
RETURN··········································· ' Send "y" to sync with receiver, then data··
' Assign simple values to ADC results
Assign0:························································· ·· 'Channel 0
·· IF (value >= 2000) AND (value <= 2500) THEN····· · 'Neutral
·· GOSUB neutral0
·· ELSEIF (value > 2500) AND (value <= 3000) THEN··· 'Slow forward
·· GOSUB Forward1
·· ELSEIF (value > 3000) AND (value <= 3500) THEN··· 'Med slow forward
·· GOSUB Forward2
·· ELSEIF (value > 3500) AND (value <= 4000) THEN··· 'Med fast forward
·· GOSUB Forward3
·· ELSEIF (value > 4000) THEN······························ · 'Fast forward
·· GOSUB Forward4
·· ELSEIF (value < 2000) AND (value >= 1500) THEN··· 'Slow Back
·· GOSUB Back1
·· ELSEIF (value < 1500) AND (value >= 1000) THEN··· 'Med slow back
·· GOSUB Back2
·· ELSEIF (value < 1000) AND (value >= 500) THEN···· ·'Med fast back
·· GOSUB Back3
·· ELSEIF (value < 500) THEN································ · 'Fast back
·· GOSUB back4
·· ENDIF
·RETURN
Assign1:···························································· · 'Channel 1
·· IF (value >= 2000) AND (value <= 2500) THEN······· ··'Neutral
·· GOSUB neutral0
·· ELSEIF (value > 2500) AND (value <= 3000) THEN··· ·'Slow left
·· GOSUB Left1
·· ELSEIF (value > 3000) AND (value <= 3500) THEN·· · 'Med slow left
·· GOSUB Left2
·· ELSEIF (value > 3500) AND (value <= 4000) THEN···· 'Med fast left
·· GOSUB Left3
·· ELSEIF (value > 4000) THEN································ ·'Fast left
·· GOSUB Left4
·· ELSEIF (value < 2000) AND (value >= 1500) THEN·· · 'Slow right
·· GOSUB Right1
·· ELSEIF (value < 1500) AND (value >= 1000) THEN··· ·'Med slow right
·· GOSUB Right2
·· ELSEIF (value < 1000) AND (value >= 500) THEN···· ·'Med fast right
·· GOSUB Right3
·· ELSEIF (value < 500) THEN································· ·'Fast right
·· GOSUB Right4
·· ENDIF
·RETURN
' Assign Subroutines
'Channel 1
Neutral0:········ ·'Neutral
· value = 1
RETURN
Forward1:······· 'Slow forward
· value = 2
RETURN
Forward2:······· 'Med slow forward
· value = 3
RETURN
Forward3:······· 'Med fast forward
· value = 4
RETURN
Forward4:······· 'Fast forward
· value = 5
RETURN
Back1:··········· ·'Slow back
· value = 6
RETURN
Back2:··········· ·'Med slow back
· value = 7
RETURN
Back3:·········· · 'Med fast back
· value = 8
RETURN
Back4:··········· ·'Fast back
· value = 9
RETURN
'Channel 2
Neutral1:······· ·'Neutral
· value = 1
RETURN
Left1:··········· ·'Slow left
· value = 2
RETURN
Left2:·········· · 'Med slow left
· value = 3
RETURN
Left3:·········· · 'Med fast left
· value = 4
RETURN
Left4:··········· ·'Fast left
· value = 5
RETURN
Right1:·········· ·'Slow right
· value = 6
RETURN
Right2:········· · 'Med slow right
· value = 7
RETURN
Right3:·········· ·'Med fast right
· value = 8
RETURN
Right4:·········· ·'Fast right
· value = 9
RETURN
ChkLink:
·SEROUT lcd,baud,[noparse][[/noparse]"?"]···················· ' Print a .if the units are not linked.
·IF Link = 0 THEN ChkLink················· ' Once the units link, then
·SEROUT lcd,baud,[noparse][[/noparse]12,"*****LINKED*****"]
·PAUSE 500·································· ·' pause to read
RETURN
·Thanks
'{$STAMP BS2}
'{$PBASIC 2.5}
' Initialize
PAUSE 2000
HIGH Dout
GOSUB Chklink
' Main
main:
convert:
Transmit:
Transmit1:
·· GOSUB neutral0
·· GOSUB Forward1
·· GOSUB Forward2
·· GOSUB Forward3
·· GOSUB Forward4
·· GOSUB Back1
·· GOSUB Back2
·· GOSUB Back3
·· GOSUB back4
·· ENDIF
·RETURN
·· GOSUB neutral0
·· GOSUB Left1
·· GOSUB Left2
·· GOSUB Left3
·· GOSUB Left4
·· GOSUB Right1
·· GOSUB Right2
·· GOSUB Right3
·· GOSUB Right4
·· ENDIF
·RETURN
'Channel 1
· value = 1
RETURN
· value = 2
RETURN
· value = 3
RETURN
· value = 4
RETURN
· value = 5
RETURN
· value = 6
RETURN
· value = 7
RETURN
· value = 8
RETURN
· value = 9
RETURN
'Channel 2
· value = 1
RETURN
· value = 2
RETURN
· value = 3
RETURN
· value = 4
RETURN
· value = 5
RETURN
· value = 6
RETURN
· value = 7
RETURN
· value = 8
RETURN
· value = 9
RETURN
ChkLink:
RETURN
Assign0:
· LOOKUP (value / 500), [noparse][[/noparse]9, 8, 7, 6, 5, 4, 3, 2, 1], value
· RETURN
Be sure to read the help file section on LOOKUP so all of this make sense -- but as you can see, one line code using LOOKUP can replace a bunch of IF-THEN statements and GOSUBs.
Not bad, huh? PBASIC rules!·
Jon Williams
Dallas Office
Post Edited (Jon Williams) : 7/28/2004 2:38:26 PM GMT
assign1:
x = value/500 max 8
ON x GOSUB right4,right3,right2,right1,neutral0,left1,left2, left3,left4
RETURN
Each one of those subroutines just assigns a new value, so that could be simplified further to eliminate the subroutines altogether:
assign1:
x = value/500 max 8
LOOKUP x,[noparse][[/noparse]9,8,7,6,1,2,3,4,5],value
RETURN
Tracy Allen
www.emesystems.com
Thanks mucho
