Problems booting BS2SX with 3 serial IO's connected
I'm hoping you can help me. I have a BS2SX with 3 serial ports
configured to communicate with some little motion controllers that
take commands via serial communications.
The problem is that when I have more of these serial devices than
one attached, and it doesn't matter which ones, the BS2SX will not
power up.
But if I only connect 1 device, the BS2SX powers up just fine. Then
I can reconnect all the others, and trip the reset on the BS2SX and
it boots up fine. But with more than 1 serial device connected, the
BS2SX won't power up from a cold power up.
Any ideas about what is keeping it from booting, and how to fix it?
/John
Post Edited By Moderator (IT Guy) : 7/27/2004 3:00:05 PM GMT
Are you able to program the stamp with the 3 serial lines attached?
If so put a debug statement at the top of your code like debug “hello” and reprogram the stamp. After the stamp is programmed leave the debug window open and power down and power up the stamp. You should see the debug display the hello again. If it does then the stamp is running and the error might be in you code. If it does not display “hello” then there might be a power problem and check the VDD pin to see what the stamp is at.
"The more you do, the more you know"
Jon Williams
Dallas Office
