Where is the bug ?
Try this simple program with a bicolor LED between pins 11 & 0 on a BS HW Board.
In the·"FOR" statement, if the TO 270 is changed to 260 or less the
program executes the correct number of times, a value of 270 or
greater causes the program to go into an endless loop. WHY?
' {$STAMP BS2}
' {$PBASIC 2.5}
' usig a bicolor led between pins 11&0
counter VAR Byte
FOR counter=0 TO 270 STEP 10
HIGH 11:LOW 0 'pin 11 hi pin 0 lo
PAUSE 50
LOW 11:HIGH 0 'pin 0 hi pin 11 lo
PAUSE 50
NEXT
END
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
PAUSE 50
PAUSE 50
NEXT
END
try using WORD as the variable type instead, allowing 65536 values.
hope this helps
"01101000 01100101 01101100 01101100 01101111 00100000 01110111 0110111 01101111 01110010 01101100 01100100 00100001"
/John
