Camera with 1bit interface for P2? — Parallax Forums
I was looking for a camera, which would be good to combine with P2. In my opinion it does not make too much sense to add a camera to P2, that produces too many pixels. Also it might be interesting to have a low number of pins in use for this purpose.
So one possibility seems to be this camera: https://docs.arducam.com/Arduino-SPI-camera/Legacy-SPI-camera/Pico/Camera-Module/Arducam-HM01B0-QVGA-Camera-Module/
Has someone tried to interface P2 with this module?
Thanks, Christof
  • RaymanRayman Posts: 16,456
    edited 2026-02-06 16:32
    Like the 1-bit/4-bit interfaces...
    That means it could work as an Eval type accessory on the usual header...
    Color version would be nice too. But grayscale also ok.
  • Looks like a nice part. The output is raw so some additional processing will be required. For machine vision applications you may not want things like auto white balance. Debayer is simple if you are downscaling by 1/2.
    Though if I needed a camera for the P2 I might use an NTSC camera because that code is already done. https://forums.parallax.com/discussion/170556/p2-ntsc-pal-video-input#latest
