Array as local variable in Inline Assembly? — Parallax Forums
bob_g4bbybob_g4bby Posts: 591
edited 2026-01-12 14:44 in PASM2/Spin2 (P2)
I wanted to declare a local variable as a small array of longs in cog ram -
pub xytopol1(buffin, buffout) | array[32], buffinptr, buffoutptr, counter
- but it makes Pnut choke with -
For access via inline assembly, a local variable must be either a long, a structure, or a pointer, and be both within the first 16 longs and long aligned. I'm guessing a Structure or Pointer refers to variables in hub ram?
Anyone got a solution?
Here's the method I'm trying to write:-
    org
        mov buffinptr, buffin
        mov buffoutptr, buffout
        mov counter, #(sigbuffsize/16)
.xypol1
            setq #(32-1)
            rdlong array, buffinptr
            qvector array, array+1
            nop
            qvector array+2, array+3
            nop
            qvector array+4, array+5
            nop
            qvector array+6, array+7
            nop
            qvector array+8, array+9
            nop
            qvector array+10, array+11
            nop
            qvector array+12, array+13
            nop
            qvector array+14, array+15
            getqy   array
            getqx   array+1
            nop
            qvector array+16, array+17
            getqy   array+2
            getqx   array+3
            nop
            qvector array+18, array+19
            getqy   array+4
            getqx   array+5
            nop
            qvector array+20, array+21
            getqy   array+6
            getqx   array+7
            nop
            qvector array+22, array+23
            getqy   array+8
            getqx   array+9
            nop
            qvector array+24, array+25
            getqy   array+10
            getqx   array+11
            nop
            qvector array+26, array+27
            getqy   array+12
            getqx   array+13
            nop
            qvector array+28, array+29
            getqy   array+14
            getqx   array+15
            nop
            qvector array+30, array+31
            getqy   array+16
            getqx   array+17
            getqy   array+18
            getqx   array+19
            getqy   array+20
            getqx   array+21
            getqy   array+22
            getqx   array+23
            getqy   array+24
            getqx   array+25
            getqy   array+26
            getqx   array+27
            getqy   array+28
            getqx   array+29
            getqy   array+30
            getqx   array+31
            setq #(32-1)
            wrlong array, buffoutptr
            add buffinptr, #32
            add buffoutptr, #32
            djnz counter, @.xypol1
    end
Cheers, bob
  • JonnyMacJonnyMac Posts: 9,828
    edited 2026-01-12 17:08
    PNut will transfer up to 16 longs from the method definition; these includes method parameters and locals. You can define the array in your code like this:
    pub method(p_in, p_out)
      org
    .done                   ret
    array                   long    0[32]
      end
    After a cup of tea waiting for the weather to warm so I can go for a walk, I tried this -- it works.
    var { globals }
      long  array1[32]
      long  array2[32]
    pub main() | i
      setup()
      wait_for_terminal(true, 250)
      repeat i from 0 to 31
        array1[i] := rndm.xrandomize(0, 1000)
      method(@array1, @array2)
        term.fstr3(@"%2d  %4d  %4d\r", i, array1[i], array2[i])
      repeat
      ' forever
    pub method(p_in, p_out) | i, x
      org
                            setq #(32-1)
                            rdlong array, p_in
                            add     array+00, #1
                            add     array+01, #1
                            add     array+02, #1
                            add     array+03, #1
                            add     array+04, #1
                            setq #(32-1)
                            wrlong array, p_out
    .done                   ret
    array                   long    0[32]
      end
    Simple, yes, but demonstrates the idea of embedding the array in your code instead of the locals.
  • Nice one Jon, I'll try that. There I was assuming that locals could only be declared in the 'PUB' line. I'll give tha5 a go. Thank you for the example.
    edited 2026-01-12 22:08
    I don't know that it makes a difference, unless you want to pre-initialize the array, but you can also create locals with RES statements. This works (after an assist from TonyB).
      org
                            setq #(32-1)
                            rdlong array, p_in
                            mov       i, #0
    loop                    altd      i, #array
    update                  shl       0-0, #2
                            incmod    i, #31                wc
            if_nc           jmp       #loop
                            setq #(32-1)
                            wrlong array, p_out
    done                    ret
    array                   res       32
    i                       res       1
      end
