CORDIC QMUL for signed multiply? Easy!
QMUL does a 32 x 32 multiply with 64-bit unsigned result. However, there is a simple method to convert this to a signed result (which I think has not been mentioned on the forum before) as follows: if one operand is negative then subtract the other operand from the high half of the result. If both negative subtract both. (The low half of unsigned and signed result is identical.)
In my view this method is better than multiplying absolute values and negating the result if only one was negative, especially for larger bit widths, e.g. 64 x 64. If the value that must be subtracted (the subtrahend) is calculated whilst waiting for the first GETQX/Y result then the conversion from unsigned to signed adds only two cycles for 32 x 32 and only four for 64 x 64.
A couple of code examples are below. Online unsigned/signed 64 x 64 multiply with user entry, showing subtraction if signed (can be used for 32 x 32 if low bits are zeroed):
https://www.cse.scu.edu/~dlewis/book3/tools/64x64Multiply.shtml
muls_32x32
'start 32x32 unsigned multiply
qmul a,b
'create 32-bit subtrahend in s
'needed only for signed result
mov s,b wc
testb a,#31 wz
if_nz mov s,#0
if_c add s,a
'read product
getqy a
getqx b
'unsigned 64-bit result in {a,b}
'subtract s from a for signed result
_ret_ sub a,s
'operands
a long $BABE_FACE
b long $DEAD_BEEF
'subtrahend
s long 0
BABEFACE*DEADBEEF =
A2705BD6,37A70A52 unsigned
0903A219,37A70A52 signed
muls_64x64
'64x64 multiply
'{a,b,c,d} = {a,b} * {c,d}
' ab
'x cd getqy,getgx
'-------- variables
' BD = b*d c,d
' AD = a*d b,c1 +
' CB = c*b b2,c2 +
' AC = a*c a,b3 +
'start four 32x32 unsigned multiplies
qmul b,d
waitx #4
qmul a,d
waitx #4
qmul c,b
waitx #4
qmul a,c
'create 64-bit subtrahend in {s,t}
mov t,#0
mov s,#0
testb a,#31 wz
if_z mov t,d
if_z mov s,c
testb c,#31 wz
if_z add t,b wc
if_z addx s,a
'read and sum four 64-bit partial products
getqx d
getqy c
waitx #2
getqx c1
getqy b
add c,c1 wc
modz _c wz
getqx c2
getqy b2
add c,c2 wc
addx b,b2 wc
getqx b3
getqy a
addx a,#0
modc _z wc
addx b,b3
addx a,#0
'unsigned 128-bit result in {a,b,c,d}
'subtract {s,t} from {a,b} for signed result
sub b,t wc
_ret_ subx a,s
'operands
a long $FFFEFDFC
b long $FBFAF9F8
c long $F7F6F5F4
d long $F3F2F1F0
'subtrahend
s long 0
t long 0
'scratchpad
b2
b3 long 0
c1
c2 long 0
FFFEFDFC,FBFAF9F8*F7F6F5F4,F3F2F1F0 =
F7F5FC0B,244878B4,213F4D4A,350CD080 unsigned
00000819,345A8CCC,213F4D4A,350CD080 signed
EDIT:
32 x 32 subtrahend code now shorter and quicker.
Great tip!
This should be in the P2 PASM manual where they talk about signed/unsigned 32bit, 64 bit and 96 bit operations...
https://p2docs.github.io/idiom.html#signed-qmul
etc, etc
(Though it really lacks an explanation as to why it works like that...)
Just saved one long and two cycles in the 32 x 32 subtrahend calculation, making this method just as quick and short as multiplying absolutes and negating result if necessary.
Replace
mov s,#0 testb a,#31 wz if_z mov s,b testb b,#31 wz if_z add s,awith this
mov s,b wc testb a,#31 wz if_nz mov s,#0 if_c add s,a
