COGINIT not working if code not reloaded? - Fixed — Parallax Forums
bob_g4bbybob_g4bby Posts: 571
edited 2025-12-20 12:47 in PASM2/Spin2 (P2)
I wanted to measure the time difference between
1. starting a cog with cog ram load
2. restarting the cog, no cog ram load
The code below does (1) but (2) fails. What have I done wrong, please, I'm going round in circles?
DAT ORG
        getct startcycle
        getct cycles
        sub cycles, startcycle          ' cycles ends up = 2
        cogid cog_id
        debug("Measurement overhead in ", udec_long(cycles))
loadandstart
        getct startcycle
        setq ptra_val
        coginit #COGEXEC+1, #@cog1start
        waitatn
        getct cycles
        debug("Time to load and start cog 1 in ", udec_long(cycles))
juststart
        getct startcycle
        setq ptra_val
        coginit #%1_0_0001, #@cog1start     ' E=1 don't reload cogram; N=0 target cog is V; V=1 cog1 is target
        waitatn
        getct cycles
        debug("Time to just restart cog 1 in ", udec_long(cycles))
        cogstop #0
cog1start
        cogatn #1
        cogstop #1
startcycle      res         1
cycles          res         1
cog_id          res         1
ptra_val        res         1
  • evanhevanh Posts: 17,127
    I didn't try to solve exactly which part was at fault, I just did a general cleanup.
    Output when compiled with Flexspin:
    Cog0  INIT $0000_0000 $0000_0000 load
    Cog0  Measurement overhead in cycles = 2
    Cog1  INIT $0000_006C $0000_0001 load
    Cog0  Time to load and start cog 1 in cycles = 22_571
    Cog1  INIT $0000_006C $0000_0001 jump
    Cog0  Time to just restart cog 1 in cycles = 22_851
    CON
        _xtlfreq = 20_000_000
        _clkfreq = 100_000_000
    DAT     ORG
            asmclk
            getct startcycle
            getct cycles
            cogid cog_id
            decod ptra_val, cog_id
    loadandstart
            getct startcycle
            setq ptra_val
            coginit #COGEXEC_NEW, #@cogruntest
            waitatn
            getct cycles
    juststart
            getct startcycle
            setq ptra_val
            coginit #HUBEXEC_NEW, #@cogruntest
            waitatn
            getct cycles
            cogstop #0
    cogruntest
            cogatn ptra
            cogid pa
            cogstop pa
    startcycle      res         1
    cycles          res         1
    cog_id          res         1
    ptra_val        res         1
    Problem with the measuring is Debug adds a massive overhead to each cog's startup time.
  • @bob_g4bby, please check the code from thread Questions about PASM2 and register allocation. It measures the startup time of a cog without debugger. It should be easy to modify it to measure what you want.
    @Kaio said:
    ... It measures the startup time of a cog without debugger. It should be easy to modify it to measure what you want.
    Bob,
    Remember to turn off debugging to eliminate its overhead.
  • maccamacca Posts: 1,010
    I think the problem is that (2) starts the Cog in HUBEXEC mode, however the start address is below $400 so it is actually a Cog/Lut exec mode, and since the previous start loaded uninitialized hub content, it executes random instructions.
    The fix should be
    coginit #%1_0_0001, #0 ' E=1 don't reload cogram; N=0 target cog is V; V=1 cog1 is target
    The start address 0 restarts the Cog with whatever the ram holds at the time.
    This is the debug output with the modify:
    Cog1  INIT $0000_0050 $0000_0000 load
    Cog0  Time to load and start cog 1 in cycles = 34_267
    Cog1  INIT $0000_0000 $0000_0000 jump
    Cog0  Time to just restart cog 1 in cycles = 33_755
    The difference is exactly 512, the clock cycles needed to load the full Cog ram.
    I have added a counter to the Cog1 code to see if the HUBEXEC start reuses the Cog ram and looks correct:
    Cog1  counter = 0
    Cog0  Time to load and start cog 1 in cycles = 51_861
    Cog1  counter = 1
    Cog0  Time to just restart cog 1 in cycles = 51_349
    This is the modified code:
    DAT
                    org
                    getct   startcycle
                    getct   cycles
                    cogid   cog_id
    loadandstart
                    getct   startcycle
                    setq    ptra_val
                    coginit #COGEXEC + 1, #@cog1start
                    waitatn
                    getct   cycles
    juststart
                    getct   startcycle
                    setq    ptra_val
                    coginit #HUBEXEC + 1, #0                 ' E=1 don't reload cogram; N=0 target cog is V; V=1 cog1 is target
                    waitatn
                    getct   cycles
                    cogstop #0
    cog1start
                    debug(udec(counter))
                    add     counter, #1
                    cogatn  #1
                    cogstop #1
    counter         long    0
    startcycle      res     1
    cycles          res     1
    cog_id          res     1
    ptra_val        res     1
    Hope this is correct.
  • Thanks everyone, instant explanations, how good is that?! I now appreciate the addressing mistake I made in the 2nd COGINIT. The code starting with code1start is loaded into cogram at 0, so the next COGINIT needs to restart at cog ram 0.
    I was expecting 'load and start' to take a bit of time, but would expect 'just start' to be quite quick, which it isn't in my debug dependent code. So like @Kaio says, you can't make a true measurement with debug active - I'll look at the code you've recommended.
    Huh, yeah, mine wasn't working correctly either.
    Updated output with corrected code placement:
    Cog1  INIT $0000_0400 $0000_0001 load
    Cog0  Time to load and start cog 1 in cycles = 22_579
    Cog1  INIT $0000_0400 $0000_0001 jump
    Cog0  Time to just restart cog 1 in cycles = 22_089
    Hubexec is 490 ticks quicker.
    CON
    DAT
            ORG     0
            asmclk
            getct startcycle
            getct cycles
            cogid cog_id
    loadandstart
            getct startcycle
            setq ptra_val
            coginit #COGEXEC_NEW, ##@cogruntest
            waitatn
            getct cycles
    juststart
            getct startcycle
            setq ptra_val
            coginit #HUBEXEC_NEW, ##@cogruntest
            waitatn
            getct cycles
            cogstop #0
    startcycle      res         1
    cycles          res         1
    cog_id          res         1
    ptra_val        res         1
    DAT
            ORGH    $400
            ORG     0
    cogruntest
            cogatn ptra
            cogid pa
            cogstop pa
  • bob_g4bbybob_g4bby Posts: 571
    edited 2025-12-22 16:08
    Still floundering around with WAITATN / COGATN - can you spot the mistake in the SPIN started version please?
    This all assembly code version works with or without debug - the LED on p56 blinks on briefly. With debug, the INIT statements make sense:-
    DAT ORG
            coginit #COGEXEC+1, #@startcog1
            cogstop #0
    startcog1
            drvl #56
            getct startcycle
            getct cycles
    loadandstart
            getct startcycle
            setq ptra_val
            coginit #COGEXEC+2, #@cog2start         ' remember - cog1start is the address to load from, but it will load to address 0
            waitatn
            getct cycles
            debug("Time to load and start cog 2 in ", udec_long(cycles))
    juststart
            getct startcycle
            setq ptra_val
            coginit #%1_0_0010, #0                   ' E=1 don't reload cogram; N=0 target cog is V; V=1 cog1 is target - and we start from address 0
            waitatn
            getct cycles
            debug("Time to just restart cog 2 in ", udec_long(cycles))
            waitx ##10000000
            drvh #56
            cogstop #1
    cog2start
            cogatn #2
            cogstop #2
    startcycle      res         1
    cycles          res         1
    ptra_val        res         1
    Debug displays:-
    Cog1 INIT $0000_0008 $0000_0000 load
    Cog1 Measurement overhead in cycles = 2
    Cog2 INIT $0000_0064 $0000_0000 load
    Cog1 Time to load and start cog 2 in cycles = 7_083
    Cog2 INIT $0000_0000 $0000_0000 jump
    Cog1 Time to just restart cog 2 in cycles = 6_555
    The following code starts with cog0 running SPIN and starting cog1 in assembly code. Cog1 should start cog2 twice, but instead gets stuck at the first waitatn. Led on p56 comes on and stays on. Running with debug, the INIT statements don't make sense - cog0 is reported as starting a cog twice, which Main() clearly doesn't:-
    '' File .......... Load and run cog versus re-run cog.spin2
    '' Version........ 1
    '' Purpose........ Measure the time to load and run a cog and also rerunning the same cog
    '' Author......... Bob Edwards
    '' Email.......... bob.edwards50@yahoo.com
    '' Started........ / /
    '' Latest update.. / /
    '' Cog0 runs a small spin program to start cog1. Cog1 loads and starts cog2, then just restarts cog2
    '' The time taken to do these two things is recorded by cog1 and cog0 displays the results in cycles
    CON {timing constants}
        _xinfreq =  20_000_000
        _clkfreq = 200_000_000
    CON {fixed IO pins}
    CON {application IO pins}
    CON {Enumerated constants}
        #0, cycles1, cycles2, PARAM_COUNT                                        ' names of global variables
    CON {Data Structure definitions}
    OBJ {Child Objects}
    VAR {Variable Declarations}
        long PARAM[PARAM_COUNT]                                                 ' this array of global vars is accessible to SPIN and PASM
    {Public / Private methods}
    pub main()
            coginit(1, @loadandstart, @PARAM)                                   ' set up cog 1 with the assembly code
    DAT {Symbols and Data}
    DAT {Data Pointers}
    DAT {Cog-exec assembly language}
    ORG
    loadandstart
            drvl #56
            setq ptra
            coginit #COGEXEC+2, #@cog2start         ' remember - cog2start is the address to load from, but it will load to address 0 in cog ram
            waitatn                                 ' wait until cog2 running
    juststart
            setq ptra
            coginit #%1_0_0010, #0                  ' E=1 don't reload cogram; N=0 target cog is V; V=2 cog2 is target - and it starts from address 0
            waitx ##10000000
            drvh #56
            cogstop #1
    cog2start
            cogatn  #2                              ' tell cog1 that cog2 is running
            cogstop #2                              ' stop cog2
    Debug displays:-
    Cog0 INIT $0000_0F64 $0000_1898 jump
    Cog1 INIT $0000_184C $0000_1890 load
    Cog2 INIT $0000_0034 $0000_1890 load
    Cheers, Bob
            setq ptra
    The problem is the address used to start the cog, it doesn't point to the correct location in spin-mode.
    One hint is that the parameter doesn't throw a compile error, it should because the location is certainly above 512 and won't fit, you must use the augs syntax with ## in that case.
    Another hint is the debug line itself:
    It tells you that the code load from location $34 that is a portion of the Spin2 Interpreter.
    In Spin mode, the address operator in the PASM blocks returns the object-relative address (actually, it is the same in PASM-mode however PASM-mode doesn't have the interpreter prepended and child objects so is equivalent), you need to use the loc instruction to calculate the actual hub address:
                    loc     pa, #@cog2start - @loadandstart
                    add     pa, ptrb
                    setq    ptra
                    coginit #COGEXEC + 2, pa
    I find loc a bit of a mistery I don't fully understand it.
    If you are using Spin Tools or flexspin you can use the special @@@ absolute hub address operator, more intuitive (but not supported by PNut):
                    coginit #COGEXEC+2, ##@@@cog2start
    I strongly suggest to use a tool that generates a human-readable listing so you can see where the code is placed in memory:
    ' Object "Untitled.spin2" header (var size 12)
    01844 00000       3C 00 00 80    Method main @ $0003C (0 parameters, 0 returns)
    01848 00004       45 00 00 00    End
    0184C 00008   000                                    ORG
    0184C 00008   000                loadandstart
    0184C 00008   000 58 70 64 FD                        drvl    #56
    01850 0000C   001 28 F0 63 FD                        setq    ptra
    01854 00010   002 34 04 EC FC                        coginit #COGEXEC + 2, #@cog2start
    01858 00014   003 24 3C 60 FD                        waitatn
    0185C 00018   004                juststart
    0185C 00018   004 28 F0 63 FD                        setq    ptra
    01860 0001C   005 00 44 EC FC                        coginit #%1_0_0010, #0
    01864 00020   006 24 3C 60 FD                        waitatn
    01868 00024   007 4B 4C 80 FF                        waitx   ##10000000
    0186C 00028   008 1F 00 65 FD
    01870 0002C   009 59 70 64 FD                        drvh    #56
    01874 00030   00A 03 02 64 FD                        cogstop #1
    01878 00034   00B                cog2start
    01878 00034   00B 3F 04 64 FD                        cogatn  #2
    0187C 00038   00C 03 04 64 FD                        cogstop #2
    ' pub main()
    01880 0003C       00             (stack size)
    '         coginit(1, @loadandstart, @PARAM)
    01881 0003D       A2             CONSTANT (1)
    01882 0003E       5B 08 7F       MEM_ADDRESS PBASE+$00008
    01885 00041       C1 7F          VAR_ADDRESS VBASE+$00001 (short)
    01887 00043       25             COGINIT
    01888 00044       04             RETURN
    01889 00045       00 00 00       Padding
    The above is generated by Spin Tools, it tells you the hub address, the object-relative address and cog-relative address of each instruction.
  • Many thanks, @macca , that's clear now. I mostly use Spin Tools with PNUT as backup. So I could use ##@@@cog2start (good grief!) and the listing feature, which I hadn't looked at closely enough.
    If you look around all the official documentation, all this addressing stuff is spread very thin / isn't mentioned, so a helping hand from a master-coder is very welcome. I can carry on with my Christmas spare-time experiments again.
    Happy Christmas, Bob
  • If measuring coginit timing with debug enables doesn't work, because debug takes quite a bit of time reporting every coginit event, what to do?
    Instead of displaying the timings using the debug window, I wrote a SPIN program to do the display, based on jonnymac's full duplex serial code from the obex - see the attached file. I use Spin Tools to compile it, because I need the built-in terminal window to display the results.
    Cogint set to load the cog ram and then run took 556 cycles
    Cogint set to just re-run the same code took 30 cycles
    So that's good. If I write a library of dsp functions, they can be loaded into cog or lut ram the once and thereafter the code is not reloaded every time a function is required, it takes around 30 cycles just to restart the cogs and call the function.
    edited 2025-12-27 20:40
    I just noticed that, by using a CON symbol DEBUG_COGS, debug functionality can be selectively enabled on a per cog basis. Which means it should be easy to both use debug for reporting the coginit() launch times while at the same time not incurring debug overhead on the measuring cog.
    Thanks for this hint, @evanh. I didn't know this symbol and I wondering when it was introduced. A search in the forum does not show any hit beside this thread.
    edited 2025-12-27 22:37
    It's always been there, just not highlighted. Looking back through stashed PDFs, I can even see it changed name where had been called DEBUG_ENABLE in v34 back in 2020.
